G-force
Old Feb 15, 2022 | 09:01 PM
Har-ray's Avatar
Har-ray
Default G-force
How many G’s can you safely pull in a Stingray?
Popular Reply
Feb 15, 2022, 11:26 PM
This is an interesting comparison, courtesy of the National Corvette Museum:
https://www.corvettemuseum.org/learn...orvette-specs/
Old Feb 15, 2022 | 11:26 PM
Old Feb 16, 2022 | 06:45 AM
NashvilleGrandSport's Avatar
NashvilleGrandSport
Great link above. Had never seen that. Thanks.
Old Feb 16, 2022 | 08:58 AM
Maxpowers's Avatar
Maxpowers
A lot of great info in that link. Thx for sharing.
Old Feb 16, 2022 | 09:24 AM
Corgidog1's Avatar
Corgidog1
There is 1 mistake in the article and it is in the gear ratio chart. Can you spot it?
Old Feb 16, 2022 | 09:44 AM
mittens's Avatar
mittens
IN a base Sting ray you can pull .7-.8 pretty regularly playing on off ramps, and curvy roads you know.
Remember anything to unsettle the car can make it break loose even if coasting just from the energy in the turn.
Old Feb 16, 2022 | 10:04 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Tell me what it is. I copied and reformatted the entire file to a word doc and then saved it as a PDF. I was going to put it in the links above as general information (with full credit to the Corvette Museum)
Elmer
Old Feb 16, 2022 | 10:42 AM
Corgidog1's Avatar
Corgidog1
Elmer
Under the chart Transmissions- under the column Stringray Z51- for 2nd gear it lists 1.066 which makes no sense. The correct number for 2nd gear in the Z51 manual is 2.07.
Old Feb 16, 2022 | 10:51 AM
eboggs_jkvl
Moderator emeritus
Much grass! I've updated the DOC and PDF. I'll check to make sure I'm not screwing with a copyright thing. Since I've edited it and made it correct, maybe I can Copyright this version!
Elmer
Old Feb 16, 2022 | 11:22 AM
Maxpowers's Avatar
Maxpowers
Good eye .
Old Feb 16, 2022 | 12:35 PM
Mad*Max's Avatar
Mad*Max
I wish the C7 would allow you to recall the highest lateral acceleration (since last start up) like the C6 does.
Old Feb 16, 2022 | 12:37 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
I've seen 1.1 in the HUD in mine. Not sure how accurate it is.
Old Feb 16, 2022 | 01:35 PM
mittens's Avatar
mittens
I can not agree more. The loss of this feature is dumb.
I also feel the same about how the move from C5 to C6, the dash buttons lost the ability to check engine code, and clear them.... C5 had that part down!
Old Feb 16, 2022 | 03:56 PM
Bill Dearborn's Avatar
Bill Dearborn
The C7 PDR lets you track your highest G force level. Just turn on the PDR and let it run while driving. Then use Cosworth Toolbox to display the highest G force seen. If you don't mark a finish line you will only get one column of data since the PDR counts the complete time it is recording as one lap.
Here is one of many track sessions I have captured:
To answer the question of how many G's a Stingray can safely pull I would say at least 1.2 G's. The chart in the link referenced above doesn't show what the G force can be when throwing a car through a corner. My car is a Z06/Z07 and easily achieves 1.4 Gs and hits 1.56 G's quite often while the referenced chart indicates it can only handle 1.2 Gs. Wheel alignment and tire choices can affect these numbers as well.
Bill
Old Feb 17, 2022 | 08:11 AM
Har-ray's Avatar
Har-ray
So, theoretically, you should be more than able to take an on/off ramp at 150-160 mph? Not that I would.😏
Old Feb 17, 2022 | 08:33 AM
Mad*Max's Avatar
Mad*Max
I don't have a PDR.
Bill
Old Feb 17, 2022 | 01:56 PM
CraigStu's Avatar
CraigStu
Friends w/ FFR cobra replicas autocrossing w/ whatever was the best Hoosier (A6?) 6-7 yrs ago regularly saw 1.4G so 1.56G in a much more sophisticated car doesn't surprise me at all. 6-7 years of tire development hasn't hurt either.
Old Feb 17, 2022 | 03:24 PM
JMII's Avatar
JMII
I've seen 1.2 to a max of 1.4g on track using an iPhone data logger with my Z51. The biggest factor is the tires. I wouldn't be doing any such testing on the street... too many uncontrollable variables. At 1g just keeping your backside planted in the seat is a challenge.
Old Feb 18, 2022 | 04:21 PM
trumanjd1's Avatar
trumanjd1
I have done 1.0 on a curved thruway off ramp with summer only tires on my 19 GS.. in mid summer .I WOULD NOT TRY IT ON THE All Seasons I am running now
To G-force
