m7
hope this helps….
GM designed the transmission to be beefy enough to safely transfer the engine power, while the Automatic Rev Match, the "nannies", and RPM limiter allow smooth shifts and minimize potential drive train damage. I wasn't a fan of the ARM initially, but use it regularly now.
A related issue is the throttle body programming that is indistinct and mushy when pulling from a start. In the first six months of C7 ownership, I had more stalled starts than in 50 years of manual trans driving. The solution was installing a Soler Throttle Body and Throttle Controller to get the throttle to respond the way it should have from Bowling Green. Lots of CF thread info on the Soler units.
Having driven almost exclusively manual trans cars for decades, aside from the throttle body issue, the C7 M7 is a decent trans (I'd give it an 8.5 - 9 out of 10) that has a couple of small issues. A common CF thread topic is the "notchy" 1-2 gear shift, and the gearshift popping out of first gear when starting off. I have not experienced the "notchiness", and a forum search will give more information. The popping out of 1st gear is usually because the shifter wasn't fully forward due to a slight misalignment of synchro rings or gears in the trans. The simple solution is to ensure the shifter is fully forward when shifting into first.
You've got miles of smiles ahead with your M7! An A8 MAY win at the track by fractions of a second, but the enjoyment of properly managing RPM, speed, gear selection and throttle lasts a lonnnngggg time!
YOU DO NOT NEED TO BUY THE SKIP SHIFT ELIMINATOR - Mine only came into play when I WANTED it to. Of course, I've been rowing gears since 1957.
Not necessary. If he's driving the C7 M7 normaly, it's a complete waste of money.
Grabbing the shifter like a pistol grip practically ensures missed shifts (other than shifting into 1st and 2nd) since you end up trying to aim the shifter into the gates and either override the transmission centering force or don't apply sufficient force to overcome the centering action when shifting to 5th, 6th, and 7th. Grabbing the shifter in a pistol grip is a sure-fire way to eventually achieve a Money Shift.
Bill
I don't use a skip shift eliminator either, just my lead foot.
Like the OP coming from an A6 C6.
A skip shift eliminator is worthwhile if you drive in busy traffic. Skip shift is easy to avoid if you drive in little to no traffic, but can be a bother when coming out of a parking ramp merging into slowish busy rush hour traffic. An eliminator gives you once less thing to think about, and you can drive the car as you would like under all conditions.
At ~ $15 and a few minutes of time a CAGS eliminator is cheap. Of course, if you drive only under conditions where is easy to avoid CAGS, do not bother to get an eliminator and save a few dollars.
I like the six speed in the C6 and camaro better, seven speed is complete unnecessary.
My last 3 “fun” cars were manuals (‘9 Z28, C5, C6) were MNs so it’s not lack of experience.
