tpms
Old Feb 23, 2022 | 05:39 PM
mmorse's Avatar
mmorse
Default tpms
i have a 2014 premiere edition that has just started its 9th year in service. i will be needing tires soon so i think that would be a good time to replace the sensors. they still work but are going on 9 years old. according to GMparts direct the part number is 13598775. is that the correct and is there any place to get them that is cheaper than GM parts direct? they want $40 each. any info appreciated. thx
Old Feb 23, 2022 | 05:43 PM
dbdoherty's Avatar
dbdoherty
I just replaced the original tires on my 2014 with all seasons at Costco. I chose to replace the TPMS at this time as well. They ran $45 each installed.
Old Feb 23, 2022 | 05:58 PM
Grand Slam's Avatar
Grand Slam
I don't know what the standard TPMS sensor life is but I had the original TPMS sensors on my C5 for 18 years and they were still working when I sold it.
Old Feb 23, 2022 | 06:20 PM
GREENKAR's Avatar
GREENKAR
Try Rockauto.com
Old Feb 23, 2022 | 07:06 PM
mmorse's Avatar
mmorse
Originally Posted by Grand Slam
I don't know what the standard TPMS sensor life is but I had the original TPMS sensors on my C7 for 18 years and they were still working when I sold it.
everything i’ve read is they last 6-8 yrs on average. sometimes a bit longer. 18yrs? that’s amazing! since the c7 has only been around for a little over 8yrs.
Old Feb 23, 2022 | 07:29 PM
MIKEZ51's Avatar
MIKEZ51
2025 C5 of the Year Winner - Unmodified
2024 C5 of the Year Finalist - Unmodified
2023 C8 of the Year Finalist - Modified
2022 C8 of the Year Finalist - Modified
Cheaper than the C5 I used to have. 40 bucks sounds reasonable.
Old Feb 23, 2022 | 08:20 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
Old Feb 23, 2022 | 08:25 PM
MIKEZ51's Avatar
MIKEZ51
Original tires also?
Old Feb 23, 2022 | 08:46 PM
Mad*Max's Avatar
Mad*Max
tpms.com
Old Feb 23, 2022 | 09:06 PM
mmorse's Avatar
mmorse
original back tires. only 24k miles on the car. had to replace the fronts around 10k miles as the original owner lowered the car without redoing the alignment.
Old Feb 23, 2022 | 09:29 PM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
Default C7 TPMS Sensors
I have a set with GM PN: 13581560 bought them from House of Wheels in Florida House of Wheels
Amazon list a second PN: 13598775
You can buy off Amazon:
13598775 13581560 SET OF 4 TPMS 433MHz Tire Pressure Monitoring Sensor Compatible With GM C7 Corvette 2014-2019
Old Feb 23, 2022 | 11:34 PM
$40 is not a bad price - I remember the early C5 sensors were at least double that.
Old Feb 24, 2022 | 04:28 AM
mmorse's Avatar
mmorse
Originally Posted by GREENKAR
Try Rockauto.com
i was told the oem sensors are made by schrader. i found this on rock auto, https://www.rockauto.com/en/parts/sc...)+sensor,12036
way cheaper than anywhere else
Old Feb 24, 2022 | 09:33 AM
Rabbi's Avatar
Rabbi
Don't buy aftermarket tpms, I wasted money on them.
Old Feb 24, 2022 | 10:49 AM
mmorse's Avatar
mmorse
what did you buy?
Old Feb 24, 2022 | 10:56 AM
Grand Slam's Avatar
Grand Slam
Oops. I meant to refer to my C5 which had the original TPMS for 18 years.
Old Feb 24, 2022 | 02:26 PM
mmorse's Avatar
mmorse
according to the ac delco site, c7 tpms is made by schrader. schrader part number 20223 is identical to gm part number 13581560. it’s the same part. rock auto sells the part under the schrader name for $21. ac delco sells the same part for much more.
To tpms
Old Feb 24, 2022 | 04:46 PM
Tommy79's Avatar
Tommy79
Default Not My Costco
My local Costco won't touch a Corvette.
I did replace the 8 year old ones in my wife's car (Discount Tire.) 3 of them were replaced under warranty in less then a year. Then a few months later, all 4 were replaced as 2 more of the cheap junk they were using died again. An email to Discount Tire Corporate office and they agreed to replace all for free. They did get smart and no longer use the "other" brand. It's a been about 2 years and no issues.
They don't last forever.. So changing out after 4-6 years is probably a good idea. Maybe someone with more info can chime in and tell us the life expectancy of TPMS.
Old Feb 25, 2022 | 09:53 AM
CraigStu's Avatar
CraigStu
If by chance you are also considering wheels, Tire Rack will mount/balance tires, install new sensors and ship to you. I don't know the specifics of the various sensor part numbers but they did a great job for me 2 years ago when I wanted to get away from the noisy stiff riding runflats. I was surprised that it wasn't until I pulled back into the garage after my first road test that I had never even seen a warning light. I autocross on the OE runflats so switch tires wheels about twice per month and the tpms system never has a problem.
Old Feb 25, 2022 | 12:33 PM
mmorse's Avatar
mmorse
thx for the info. i have a really good tire place by me. when i do get new tires, they won’t be runflats. during the colder months, they literally jump on tight turns. feels and sounds like the front of the car is falling apart. they don’t properly track at all. GM says it’s fine and won’t hurt anything but it certainly doesn’t feel or sound that way. the side walls are way too stiff for the cars suspension. at least they are for the z51 suspension. just trying to save a couple bucks on new sensors.
