2016 coupe
Old Mar 16, 2022 | 04:04 PM
Chiefc1's Avatar
Chiefc1
1st Gear
Default 2016 coupe
Has anyone experienced the shuddering at highway speeds….it feels like you’re going over rumble strips especially on acceleration. Comes and goes but you definitely feel it.
also, wind noise coming from the hatch..
Old Mar 16, 2022 | 04:14 PM
Red08's Avatar
Red08
I have a 14 coupe. I have never experience that. What tranny do you have?
Old Mar 16, 2022 | 04:43 PM
jwmgr8's Avatar
jwmgr8
if it an A8 automatic transmission it is likely the dreaded transmission shudder. Check with local chevy dealer and ask them if your VIN has had the triple flush? If it has it might need another or its something else?
If it has not you'll need to do it.
I also like having a Range device to eliminate switching to 4cyl operation?
Old Mar 17, 2022 | 08:52 AM
^ good advice. Hopefully it is just in need of the triple fluid flush and that will solve the shudder issue.
Old Mar 17, 2022 | 10:12 AM
Catfish4818's Avatar
Catfish4818
We bought our 2015 A8 with 13K miles in early December, and had the same symptoms as you report until we had the triple flush done in mid-February.
Old Mar 17, 2022 | 10:56 AM
JHundertmark's Avatar
JHundertmark
Our 2016 Z51 had the triple flush with the new ATF in Sept 2019 & no shudder. Was covered under warranty - Reference TSB # 18-NA-355.
In addition, since then I've also run with the Range AFM Disabler.
Good luck.
Old Mar 17, 2022 | 11:58 AM
Walter Raulerson's Avatar
Walter Raulerson
Here's my story My '15 had the shudder so I took ir the dealer they kept it a week I think 3 flushes was the recommendation from GM. Well it happened again and I took it to a Cadillac GM dealer that has all kinds of certified mechanics and it was fixed that afternoon. I asked how did you guys do that so quickly and of course they had a machine that drained the car and filled it in a mater of minutes EUREKA no problems since. That's the difference in an up to date dealership and one that won't spend the money on new technology to help the customer and them selves. They take car of my car.
To 2016 coupe
