changing oil
Old Mar 31, 2022 | 10:01 AM
Bills17n72's Avatar
Bills17n72
Default changing oil
ok my car has been sitting since december , i know all the oil is in the oil pan ,would it be better to change the oil while the oil is in the pan ,or should I start the motor up and get the oil hot then change it ,just wondering! thanks Bill
Old Mar 31, 2022 | 10:04 AM
JUICEBOX's Avatar
JUICEBOX
Veteran: Marine Corps
If it’s been in cold storage, start it up and let it warm up to temp before changing. Will most likely have a lot of moisture.
Old Mar 31, 2022 | 10:28 AM
JHundertmark's Avatar
JHundertmark
For many years I would always run the vehicle & change the oil while warm or hot, however, a couple of years ago Road Racing World did a test with data on the drained oil to determine if there was any difference in draining engine oil cold, warm, or hot. They found no difference so I have modified my practice. I always let the oil drain for a substantial period of time.
Old Mar 31, 2022 | 10:44 AM
A number of sources advise on letting the oil warm up by running the engine for a couple of minutes before doing the change - warming also helps the oil flow faster when the drain plug is removed.
I have to admit that I do not always get the oil warm before starting the work - it just takes longer for the oil to drain.
Old Mar 31, 2022 | 10:46 AM
Elk's Avatar
Elk
What differences did their test look for?
For me the issue would be getting out the old oil. An extended drain time would essentially address this.
Old Mar 31, 2022 | 11:56 AM
Maxpowers's Avatar
Maxpowers
Yup. Warm oil drains quicker and picks up the sediment.
Old Mar 31, 2022 | 04:50 PM
Red08's Avatar
Red08
I have been changing my oil for more than 50 years. I always drain the oil with the engine being warm.
Old Mar 31, 2022 | 07:59 PM
iclick's Avatar
iclick
Ditto.
Old Mar 31, 2022 | 08:23 PM
yaknow's Avatar
yaknow
not quite 50 years but
Old Mar 31, 2022 | 11:20 PM
aklim's Avatar
aklim
That to me would be the question. Is the force of the oil going out going to pull sediment out, assuming there is any and how much sediment is there? Since someone did the test already and didn't find any difference, could we be trying to get sediment that isn't there since it might already be filtered out? Do I agree that hot oil drains faster? Absolutely. Unfortunately, in the C7 you can't suck the oil out of the dipstick tube. On my MBs that is what I do so getting the oil moving is important.
Old Apr 1, 2022 | 07:19 AM
DALE#3's Avatar
DALE#3
I think a vehicle sitting for a length of time all crap.Or most of it had plenty of time to hit the pan.Starting up the vehicle spreads the crap,again.
If you prefer to jack your vette from the side?This can be done without starting and traveling up ramps.
I just changed the oil on the Harley last nite.Never started it,crap has settled and believe more is out than starting it.
Really how would you actually know what is better
Old Apr 1, 2022 | 10:31 AM
Mad*Max's Avatar
Mad*Max
By the time I start the car, aim and get it up on the ramps, the oil is warmed up nicely so I really don't have a choice either way (unless I put it up on the ramps and leave it for several hours to cool down again which is not gonna happen).
Old Apr 2, 2022 | 12:20 AM
LT4CMG's Avatar
LT4CMG
I’ve been storing cars for years. I dump in the spring before the startup. All the crap has drained into the pan for 5 months. Why run it through again?
Old Apr 2, 2022 | 08:12 AM
Brunello's Avatar
Brunello
I don’t know if this is right but it sounds right. If we’re going to be following unscientific, “well in my day” practices, “sounds right” is about as good a rule as any. I just did this so that also makes it the “right” way.
Old Apr 2, 2022 | 08:22 AM
Tinkertech's Avatar
Tinkertech
If you drain the oil when it is hot then all the 'gunk' is now in suspension with the oil and will come out wit it.
Old Apr 2, 2022 | 08:51 AM
Zjoe6's Avatar
Zjoe6
Moderator
Always do mine warm. Wonder what the manual says. I do like the argument that warm oil flows faster and flushes out the crap better.
Old Apr 2, 2022 | 11:52 AM
LT4CMG's Avatar
LT4CMG
we can split hairs forever, but the bottom line is, it’s an oil change, not brain surgery. All my other cars get “hot” oil changes. My stored cars get cold ones. Take off the plugs and let it drip a few hours until nothing comes out anymore. Refill with 0/40 esp (in my case), 5/30 in most other cases. No matter what your preferred method, doing it yourself sure beats the hell out of having the “oil change tech” whatever the f… that means, do it. Not sure what degree qualifies you as an “oil change tech”, but the dealerships love those important sounding designations.
To changing oil
Old Apr 2, 2022 | 12:15 PM
JHundertmark
Everybody is entitled to their own opinion, & as I stated earlier, for over 50 years I changed oil hot, until reading article & test in September 2019 Road Racing World.
They got the greatest amount of oil out of the engine using a cold drain, hot was second greatest amount of oil, & warm was the lowest amount of oil.
Their theory & I don't have enough data to disagree with it is that the cold oil has all collected in the sump resulting in the most oil drained. When hot, there is oil on the crankcase walls that doesn't all drain unless you leave your drain running for a long time. Warm was the worst since oil got splashed on the crankcase walls & being warm took the longest to drain down.
Sorry to stir everyone up again, however, I now change oil cold, & I do use an extended drain time. Since it's in a warm garage I can do other things & have a cold beverage.
Take care
Old Apr 2, 2022 | 12:36 PM
Elk's Avatar
Elk
This makes as much sense as everything else propounded in this thread.
Bottom line: change your oil in whatever way you would like. It is an oil change, not rocket science. These cars are not fragile.
Old Apr 2, 2022 | 12:49 PM
Mad*Max's Avatar
Mad*Max
If I use ramps do I need to use a jack to raise the rear end and level it to maximize extraction?
