Emissions Testing
Old May 11, 2022 | 08:08 AM
Nvr2late's Avatar
Nvr2late
Default Emissions Testing
Know there are lots of posts on this subject; but, am lousy at searching on the forum.
Live in MD and just got my first notice for an emission test on my 2019 C7. Have been using the range device with great results since I purchased it new. How many miles or hours do I need with the Range out to safely pass emissions?
On a side note, I am visiting the Corvette Museum this summer for the first time. Any attractions nearby to keep my wife happy?
Thanks for the anticipated help and advice!
Old May 11, 2022 | 12:59 PM
Nvr2late's Avatar
Nvr2late
Sorry everybody! Think I confused many readers. I still have the C7 mentioned. Same questions still apply. Just chalk it up to my dumb ***! Still need the advice
Old May 11, 2022 | 02:28 PM
9sec's Avatar
9sec
google gm drive cycle for readiness monitors. tells you exactly what's needed
Old May 11, 2022 | 11:05 PM
Mad*Max's Avatar
Mad*Max
You can visit Mammoth Caves.
Old May 12, 2022 | 12:10 AM
AirOpsMgr's Avatar
AirOpsMgr
Dir. of Lavatory Services
If I recall correctly, I pulled my range device and did around 50 miles before hitting the emissions "hut" without any issues (With a Corsa Double-Helix X-pipe minus secondary cats).
With that said, I'm about to do it all over again in the next few days as my Birthday Tax is coming due in June. Will report back if I have any issues.
Brgds,
Old May 12, 2022 | 07:09 AM
NashvilleGrandSport's Avatar
NashvilleGrandSport
From RANGE website:
https://www.rangetechnology.com/support/
What do I do if I have to do an emissions test?
As with any device that plugs into the OBD2 port, you should REMOVE THE DEVICE AND DRIVE IT SEVERAL TIMES/MILES before taking it into the center for testing. This will force the vehicle to reset all the "OBD2 READINESS MONITORS" and to be prepared for the emissions testing (whether it be on the rollers or just an OBD2 "sniff" test).
The Range module doesn't affect emissions but because we take control of the AFM system, the vehicle may have an OBD2 Readiness monitor show "Not Ready" because it wasn't allowed to run (no V4 mode with the V8 module, for example). The easiest thing to do is just unplug the module and run the vehicle a couple of days without it to be absolutely sure that everything gets a chance to run.
Another good thing to do is top off your tank and drive 50-100 miles total before performing the test (this has nothing to do with the Range module). This allows the EVAP system to perform a proper "purge test" and pressure cycle, which will allow the EVAP OBD2 READINESS MONITOR to show "complete."
To Emissions Testing
