worth getting small leak fixed?
Old Jul 17, 2022 | 08:51 AM
dvilin's Avatar
dvilin
I would get it fixed.
Old Jul 20, 2022 | 11:52 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Originally Posted by TxC7
I have a 2019 GS M7 with 9000 miles that is seeping a small drip of red transmission fluid at the junction of the manual transmission housing and the extension housing, and I'm debating whether to have it repaired (I have an extended warranty). Everything on the car is working perfectly, and I have the suspension perfectly tuned for my weekend track events. I fear that the repair will involve dropping the rear end and even tilting the motor down to open up space at that junction.
Yes, you guessed correctly that I don't have the most faith in the techs at the dealership to put everything back perfectly. Even in experienced hands, this sounds like a multistep process with a lot of areas for problems in reassembly. Should I just let it go until closer to the end of my warranty while regularly checking the transmission fluid level? I change all my own fluids a lot since I do track the car.and constantly inspect the whole vehicle on a lift.
Thank you for your opinion!
This is certainly not what we like to hear, TxC7. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 GS M7. To do so, please send an email to socialmedia@gm.com with ATTN: TxC7/Corvette Forums in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
Old Nov 29, 2022 | 12:07 PM
RRRRED's Avatar
RRRRED
Hi Har-ray,
I have a leak in the rear housing, and it sounds very similar to your experience. I also have the Platinum warranty. Did you have any trouble getting them to cover this repair? The dealer is quoting me $4,000 to fix it.
Thanks,
Alton
Old Nov 29, 2022 | 12:30 PM
orca1946's Avatar
orca1946
Glad to hear no more leaks!
Old Dec 5, 2022 | 02:14 PM
miami08VETTE's Avatar
miami08VETTE
Thank you everyone- my plan will be to take steps towards fixing it sooner rather than later. First I'll wash it down and put some street miles on it to see if its like Bill suggests and only some track related blow by. If just regular driving creates the drip, a visit to the dealer will be indicated - after some "interviews" with the local shop foremen since my two trusted referral techs have moved on. I don't want to experience a seal failure, but I'm enjoying the car sooo much right now with everything working beyond perfectly that I can't bear the thought of the return visits to sort out new issues related to the repair process. I don't want to be too negative, but I've learned that if you're expecting a delivery it will be late, if its furniture it will be damaged, if its mechanical it won't work, and if its quick information that you need, you'll be forwarded to a voice mailbox that says that its full.
My GS developed a Transmission leak when the car only had 1900 miles on it. The dealer originally identified as a seal leaking. They fixed and wipe everything down. 2 weeks later the drip was back. Turned out to be seepage coming through the casing itself. They replaced the transmission. Problem solved. So could be nothing but could be major. Let the dealer do a thorough inspection and get to the root of the problem. If you're like me, the slow drip will drive you crazy!
