Having just moved from a C6 GS Vert to a C7 Z Coupe I can tell you there IS a difference!
Gas Mileage: My C6 GS had CAI, headers, and high flow cats, with NPPS (auto) and I typically got 17-20mpg. My new Z (manual) only mod so far is a Corsa X pipe and I'm getting 20mpg on avg. Insurance: I can see vey little difference (less than $50 year) in my policy. Now my cars were a 13' and a 16' and I keep them on a low mileage (less than 5k a year) policy Fun Factor: The feel and power behind the wheel of the Z is a WHOLE new level compared to my GS (even after an extra 50+ HP added with aftermarket stuff).
Last thing to consider: The Z WILL hold a higher resell long term over the GS.
I believe the OP wants to compare C7 GS to C7 Z06. I would say there is also a quite a difference between a C6 GS and a C7 GS. Even with my lead foot and town running, I average 19mpg and on the highway, I regularly see 28-32mpg average staying +5 on the speed limit.
The higher resale value is relative. If you are buying a second hand Z06, you are paying a higher price now and you will never recoup that extra when you sell (unless you can keep it in pristine condition for 50 years, then it would be the same for a well kept C7 GS).
If money is no option, go for the Z06, but the only advantage the Z06 has is the extra power. No one needs these vehicles, it is purely a want, so if you want the 650/650 for what ever reason, it is your decision.
Do you have a place to use the extra power is the real question?
I lost interest in the Z06 when I realized that I wouldn't really have a place to enjoy being able to smash the gears without going to jail. Even with 460HP, It only takes 1 shift and few seconds to be breaking speed limits.
If I lived in areas where the speed limit was 70-80 everywhere, that would be a different story.
I think 70-80 is still not enough. I would have to live in Germany with Nürburgring on one side and the Autobahn on the other to want the Z06. Where I live, with a C7 Z06, one ca go to jail in about 6 seconds, with a C7 GS it is about 7.4 seconds.
ANY 2014 - 2019 will; "put you in jail." That's not a reason to base a decision on which one to buy.
You want the Z06. Don’t shortchange yourself with a lesser car.
Agreed. I thought I would be content saving a few bucks and going with the Z51 with grandiose plans to put an aftermarket blower on it...exactly 1 year later and I just traded up into a Z06.
You make the decision ! Both are great cars. Just get to know the Z before you get in trouble with the X-tra horses.
Good luck with your choice !!
Rich
Z06, maybe stick with a Z06 but without Z07 to mellow it a bit. I think you'd regret not going for the Z.. you can drive both the same and always use more or less, of the Z's power, but if you want it and it's not there.. your SOL. The wheels are not every single car.. many are fine and you just need to be careful. In terms of wheels either forged or cast, you always have to exercise common sense. No wheel that wide with those areas of basically unsupported structure can bend.. just a matter of physics. I tracked my 17' and had no cooling problems whatsoever. I don't hear valve problems as much as people on wheels and cooling, but it can happen.. I think C6-C7-C8 all have some problems like that REMEMBER this IS a GM product after all Good luck on your decisions hope to see a pic here of it soon.
The most preferred is the 2019 as it has some suspension updates, the ZR1 low side fuel pump, rear differential and a revised Track display. But at least the 2017+ model as it has improved cooling and pulls less timing due to blower heat soak than the 2015-2016 years. However, any year C7 Z06 will be better than a Grand Sport in my opinion.
I was in the same boat as you last year. I was moving up from a C6 Z51. When I drove the GS, the driving experience wasn't all that much different from the C6. Sure, it is smoother & handles better; but the power & sound is pretty much the same. I decided to spend the extra money on the Z06. I didn't want to be second guessing my self later, and regret my decision.
Man, am I glad that I bought the Z06. Stock (like many cars), the throttle has a ton of lag, and it almost makes the car feel heavy. So, I installed a freer-flowing air filter, a Soler ported throttle body, and a their throttle controller. The throttle response is now extremely responsive & linear. This car is scary fast. It doesn't scare me, but it scares almost everyone else in the passenger's seat.
The only thing about it is that you do have to be careful when you're pushing it hard on the street. You'll have to be more cautious & smooth with your throttle input than you would with the base / GS engine. You MUST run summer tires. All season tires, which I only run during the cold weather months, are no match for this car's power.
That's a good point. I had forgot that the 2019 Z06 got a lot of upgrades the ZR1 got for simplicity of the production line. Listed are some components.2019 updates/upgrades
1) Better cooling with larger radiator 2) Updated reservoir 3) Improved (Beefier) upper control arms 4) Updated track dashboard 2018's and newer 5) Better fuel system from the ZR1 6) Better MRC shock mapping (although 17's can be reflashed for a price) 7) Better PDR cameras 8) Better rear diff with the ZR1’s spider gears 9) Better paint, fit and finish from the upgraded BG facility
Absolutely, I agree 100%. At the same time the OPs decision should be based on what his needs, wants and means allow. Like I said, he cannot go wrong with either.
You don't need to replace with forged wheels; a higher quality cast or flow formed wheel will be exponentially more reliable than the stock wheels and more than durable enough to handle daily driving.
i replaced mine with granite, had them made out of some old counter tops I was getting rid of.
If you are looking for the forum opinion on which one to get, you are going to see that those that have a GS will tend to steer you towards a GS and those that have a Z06 will tend to steer you towards the Z. After all they bought their car because that is what made most sense to them and fit their needs..
I got a GS because I could not justify the extra $10-15K for the Z06.
If money was not a concern, I would go with the Z06. However, there is absolutely nothing wrong with choosing a GS as it is more than capable on the street and track. Tough choice to make.
I looked and contemplated for a year plus. Z or GS.
Then prices shot up. Money was not a concern.
Sure the Z has more hp, but I can get a ticket just as easy with the 460 hp in a GS.
I did settle on the GS Collector Edition and have been very happy.
The GS is pretty much the Z without the added HP.
Sure the wheels may crack someday but ok, then I get forged.
Go with what you can afford and have fun.
Good hunting.
