Help!!!
Old Jul 28, 2022 | 06:45 PM
midlifetoy1's Avatar
midlifetoy1
Default Help!!!
Car (2016 Z51 vert) died when I got to work. No power at all! Figured it was the battery so had wifey pick up a new die hard. Got it installed and when neg cable is connected trunk, tail and side lights come on. Now the problem...
the dors will not open and when I try to start it all I get is a ding, ding, ding. Windows will work, but rest of interior is dark
can someone please call me and maybe help ne get this fixed? My number is 404 915-3587. Please help. I don't even know how I can get it towed as it won't shift to neutral.
Old Jul 28, 2022 | 06:59 PM
wrecker3's Avatar
wrecker3
Check all nuts are tight where the cables attach to the power block.
Old Jul 28, 2022 | 07:27 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I agree!
Everything must be aligned like it came from the factory. The nuts need to be good and tight. Confirm that the little black wire on the negative post is still there and attached.
Elmer
Old Jul 28, 2022 | 07:45 PM
midlifetoy1
Yall are right on point. got it started, battery at 14.5V according to the dash readout. Just on little quirk, the trunk will not stay latched. if i push it down, it will pull as if latching, but will then release. I've tried closing it multiple times with no luck. could it be a fuse?
Old Jul 28, 2022 | 08:15 PM
GregMIC7's Avatar
GregMIC7
I recall reading a thread a while ago about the trunk not latching. Try doing a search on "trunk latch" or something similar, see what comes up.
Old Jul 28, 2022 | 08:30 PM
GregMIC7's Avatar
GregMIC7
Check this thread
Hatch/trunk not closing (coupe) - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Jul 28, 2022 | 09:49 PM
Avanti's Avatar
Avanti
For future reference, add: cable connectors need to be clean and not corroded, as well... plus, a known good battery in the FOB with all buttons, clean, free, and easily functional. Sounds like you're nearly good to go!
Old Jul 28, 2022 | 10:12 PM
RonC7's Avatar
RonC7
14.5 V is the charging voltage with the engine running. A fully charged battery should be at or above 12.6 V.
If you disconnected the two flat bus bars on top of the battery, they need to be in good contact and flat to each other before tightening the bolt back.
If still a problem, check voltage downstream of each fuse on top of the battery. You may have managed to blow one. The good news is that there is a spare 100 amp fuse. Since the car starts you did not blow the 350 amp fuse.
Ron
Old Jul 29, 2022 | 08:49 AM
Glad you got the car running again and good luck with the trunk latch problem.
Old Jul 29, 2022 | 01:32 PM
Skid Row Joe's Avatar
Skid Row Joe
Good going! 👍
Old Jul 29, 2022 | 03:16 PM
Richard Ames's Avatar
Richard Ames
I was having work done and the trunk quit latching. Replaced latch and the old one was out of adjustment and only did the first latch and it failed.
To Help!!!
