Soler Throttle Controller
Old Sep 14, 2022 | 07:46 AM
bluegoatee05's Avatar
bluegoatee05
Default Soler Throttle Controller
Question for those that have had both the original model, and the new Bluetooth compatible model; other than the obvious addition of features, and the additional modes, in the modes that are common between the two, have you noticed any difference between the two? I see that there are a few of the older models always for sale in the for sale thread, and occasionally the new model, which always sell pretty quickly.
I'm not sure that I need all of the additional modes that are in the newer model, and might be perfectly happy with the older model, but wanted to see about potential differences in feel for those that have had both.
Old Sep 14, 2022 | 08:51 AM
Maxpowers's Avatar
Maxpowers
You may want to reach out to Mike @ Soler to see if the TC maps have improved or if its just the interface.
Old Sep 14, 2022 | 09:40 AM
Raidercop's Avatar
Raidercop
I didn't have the original model but from my experience the BT version means you can install it hidden and control it with the App. So easy to use and worth the extra $ to not have to run wires, take interior pieces apart to have constant access to it. Mine is behind the carpet by the gas pedal. No exposed or even needing access to.
Old Sep 14, 2022 | 03:30 PM
vetterich's Avatar
vetterich
I 2nd what Raidercop says. Who wants to stick the display unit anywhere on the dash so it's visible. Hide it under the carpet and forget it, use your phone to control it. As for all the extra settings....why not?? You have so many ways to customize just to your liking.
And did I mention the customer service?? 2nd to none, Mike answered my email in less than 5 minutes
Old Sep 14, 2022 | 03:38 PM
jwmgr8's Avatar
jwmgr8
Does anyone know if the BT controller can just sit in the dash hidden compartment behind the screen or am I missing the connection to the pedal??
Old Sep 14, 2022 | 04:54 PM
NortonCO's Avatar
NortonCO
@Mike@SolerEngr is both knowledgeable and responsive.
Both the original and BT can be installed inconspicuously. It is, however, easier with the BT version.
Assuming I understand your question correctly, you're missing the connection to the pedal. Suggest reviewing (pages 3-5 of) the User Manual.
Old Sep 14, 2022 | 05:49 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Once you connect wire to foot pedal you can put it anywhere you want.. I mounted mine under dash area , I can pop it off if ever needed, but never have had a reason to yet..
Old Sep 14, 2022 | 06:36 PM
1FINE99's Avatar
1FINE99
Cruise-In IV Veteran
Cruise-In V Veteran
I have mine unplugged from the pedal device and it is in my center console . Control everything with my phone !
Old Sep 14, 2022 | 11:13 PM
I agree with this comment. I originally ordered the non-Bluetooth version, but never installed it. When the Bluetooth version came out, I made the exchange with Mike at Soler (was not that long between the two versions at that point) and have been very happy with the Bluetooth. Can control it with my phone and not have to mess with a small control unit.
Old Sep 15, 2022 | 10:52 AM
Maxpowers's Avatar
Maxpowers
I installed mine under the arm rest. Truth be told....after the first week I determined Sport 6 (Vitesse) is what I like. Never changed it in the years since. Could have just kept the controller under the carpet.
To Soler Throttle Controller
