Fueling difficulty.
Old Oct 2, 2022 | 08:50 PM
Jmhornz71's Avatar
Jmhornz71
If you keep clicking on the pump, to get that little extra in, after it shuts off gas can get into the evap cannister clogging it and if that happens it will shut of the gas pump after just a little gas being pumped, expensive to have repaired
Old Oct 2, 2022 | 10:18 PM
aklim's Avatar
aklim
Originally Posted by Zeek
I have tried to fill the tank on my '15 convertible three times now. Even tried different gas stations. It keeps shutting off the fuel nozzle way before half tank. No matter how slow I try to put fuel in, it just keeps bubbling up the neck.
Stupid question but how do you know this? The C7 is 18.6 gallons so it isn't a lot (had an excursion with a 44 gallon tank which you can get 46 in if you tease the pump and have the vent modified). Are you sure the gauge is accurate?
Old Oct 4, 2022 | 09:35 AM
jwmgr8's Avatar
jwmgr8
I've had similar problem, but it seems to be the way the gas pumps vapor sensor or their filter or ??? but seems to be gas pump. I usally get gas at a Buckeys that has like 200 gas pumps and it happens at the same pumps most of the time, but if I go to another pump it goes away?
Old Oct 4, 2022 | 10:55 AM
Carvin's Avatar
Carvin
St. Jude Donor '15-'16
Yes, occasionally I come across a pump with no problems. Wild guess is around 30% of the time.
Old Oct 4, 2022 | 01:18 PM
vader86's Avatar
vader86
Happens all the time to me, I pull the nozzle about half way out, and then turn the thing mostly upside down. Also best to not fill at full nozzle speed when it starts hiccuping like that.
Its annoying
Old Oct 4, 2022 | 01:46 PM
Vipula AD's Avatar
Vipula AD
Does this at every pump I have tried, except when the gas is coming out of the pump very slowly. I turn the nozzle at 90 or just past 90 degrees and it works. I do get the occasional strange look from others at the gas station when I am doing the gangster hold on the nozzle.
Old Oct 4, 2022 | 01:50 PM
aklim's Avatar
aklim
Can't say I have ever had to do that on a regular basis. There are a few here and there I have run into.
Old Oct 4, 2022 | 06:45 PM
Avanti's Avatar
Avanti
I turn the nozzle to the side and, depending on the pump, the flow speed varies. Yet, sometimes I've found a pump that works fine. Go figure. (btw, patience is a virtue)
Old Oct 5, 2022 | 02:16 PM
RichAshley-Black99's Avatar
RichAshley-Black99
This happened on my 15 stingray, I ended up replacing the following parts. I tried all the different angles while fueling and different stations and pumps. Nothing worked. My Vapor Canister ended up being clogged up.
Vapor Canister mpn # 4901340060
Vapor Canister Purge Valve mpn # 4410656845
Vapor Canister Vent Solenoid mpn # 4666096644
-Rich
Old Oct 5, 2022 | 10:30 PM
Zeek's Avatar
Zeek
St. Jude Donor '07, '11 thru '24
Official Sponsor of the 60 Day VacatioNN
10,000 poster in the "thread" Part II
-Rich
Is this a pretty simple and straight forward replacement? Sounds like this may be my problem.
Old Oct 6, 2022 | 09:09 AM
Zjoe6's Avatar
Zjoe6
Someone in the C7 ZR1 forum had this issue and ended up taking it to the dealer. Not sure what happened after that. Probably same as post #29.
Old Oct 6, 2022 | 10:21 AM
aklim's Avatar
aklim
-Rich
Fair enough but what does the valve and solenoid have to do with it if the canister is clogged?
Old Oct 7, 2022 | 01:12 PM
  #33
c5arlen's Avatar
c5arlen
What year model C7 did GM fix this big-time annoyance? Has every C7 have this fueling problem?
You guys realize that the "vapor recover system" requires a seal and having the fuel nozzle half in or half out defeats the purpose and is not legale... You could go to "Q".. for heaven sakes!
Old Oct 7, 2022 | 01:15 PM
  #34
Maxpowers's Avatar
Maxpowers
Delete. Posted in wrong thread.
Old Oct 20, 2022 | 02:47 PM
  #35
RichAshley-Black99
When researching the issue the others initially could have been a culprit as well. Process of elimination lol. I started with just the vapor canister purge valve, that didn't fix it. I then moved on to check the cannister I figured since I was there might as well replace the solenoid as well. Anyhow the canister was clogged easy fix maybe $200 total I think.
