Fueling difficulty.
Old Oct 1, 2022 | 10:05 AM
Zeek's Avatar
Zeek
St. Jude Donor '07, '11 thru '24
Official Sponsor of the 60 Day VacatioNN
10,000 poster in the "thread" Part II
Default Fueling difficulty.
I have tried to fill the tank on my '15 convertible three times now. Even tried different gas stations. It keeps shutting off the fuel nozzle way before half tank. No matter how slow I try to put fuel in, it just keeps bubbling up the neck.
Old Oct 1, 2022 | 10:45 AM
BAT's Avatar
BAT
2026 Corvette of the Year Finalist - Modified
2025 C7 of the Year Winner - Modified
2024 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
2021 C7 of the Year FinalistAX - Modified
Rotate the nozzle so it's up side down
Old Oct 1, 2022 | 10:56 AM
Vette_DD's Avatar
Vette_DD
Several of the pumps at the Kroger gas station where I trade do that. I just hold it on the first click of the pump with my finger until I get a stronger disengage from the pump handle.
Old Oct 1, 2022 | 11:19 AM
ICONIC7's Avatar
ICONIC7
2025 C7 of the Year Finalist - Modified
Just pulling the nozzle out slightly. I've found that I usually have problems if the nozzle is shoved all the way in.
Old Oct 1, 2022 | 11:26 AM
Vette Ski's Avatar
Vette Ski
I found the upside down version part way out helps.
Rich
Old Oct 1, 2022 | 11:33 AM
socal_tom's Avatar
socal_tom
I just pull the seal back a little, never a problem
Old Oct 1, 2022 | 01:42 PM
dvilin's Avatar
dvilin
This works for me also.
Old Oct 1, 2022 | 01:55 PM
rfh928's Avatar
rfh928
That works perfectly for me also. Tried partially turning it...but totally upside down is the only way it works consistently without shutting off. I have a 2019 coupe, so likely all models have this issue.
Old Oct 1, 2022 | 02:23 PM
Vette Ski's Avatar
Vette Ski
Yep, I have a '19 GS. Will try part way out next time. Been doing upside down.
Thanks, Rich
Old Oct 1, 2022 | 02:43 PM
This seems to work for some cars. And as stated, not inserting the nozzle all the way in helps also.
Old Oct 1, 2022 | 03:13 PM
Zeek's Avatar
Zeek
Thanks for the suggestions and input. Unfortunately, I have already (obviously) done all these methods to no avail.
Old Oct 1, 2022 | 04:31 PM
Vette Ski's Avatar
Vette Ski
Go to an EV
Rich
Old Oct 1, 2022 | 06:34 PM
ArchitectMike's Avatar
ArchitectMike
Upside down is foolproof, plus it keeps the vapor collection device (if the pump has one) sealed tight to the filler neck.
Old Oct 1, 2022 | 09:00 PM
ZO6LIFE's Avatar
ZO6LIFE
Instead of upside down, mine seems to prefer a 90° pitch. Definitely a pita.
Old Oct 2, 2022 | 09:29 AM
Elk's Avatar
Elk
I find inserting the nozzle only until it is past the second flap works well.
It is a silly, fussy process.
Old Oct 2, 2022 | 11:06 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
I do not know if they have done something to the nozzles at Costco, but, the last four times I have gone there, I forgot, put it in the normal way I do for our other cars, and I did not have to fool with the nozzle,. I just put it in and it worked.
Old Oct 2, 2022 | 01:50 PM
Carvin's Avatar
Carvin
St. Jude Donor '15-'16
IOW, you're not fully inserting it? I have used that. Also slowing the fill rate or both. Agree, it is reedick. Happens on maybe 75% of pumps.
To Fueling difficulty.
Old Oct 2, 2022 | 01:51 PM
Maxpowers's Avatar
Maxpowers
Same here. The Costco ones around here flow slower and dont stop early. Good for the C7. Not so good for the 23 gallon tank in the Jeep on 95F days.
Old Oct 2, 2022 | 03:26 PM
jdaniels138's Avatar
jdaniels138
Veteran: Marine Corps
I fill up at Costco and tilting the bottom to about 5 o'clock usually works for me. Sometimes it works just fine at the normal position. Not my daily driver so I don't have to do it that often.
/JD
Old Oct 2, 2022 | 04:29 PM
sprink94's Avatar
sprink94
I have not had that problem with a Corvette but my brother and I have both had it with late model Escalades. Seems that there is a Charcoal Cannister that catches gasoline fumes and has a service life of only 5 years or so. We both run Diablo Tune Tuners and were able to do resets that cured the problem for a few months...then it returned. On my brothers Escalade we discovered that the circuit was shared with the cigarette lighter and the fuse was blowing each time this happened.
In the end...we both replaced the cannister that on the SUVs was in front of the filler neck tube. Not sure if Corvettes use the same system but it's worth looking in to.
Good Luck!!
