Wheel size
Old Oct 19, 2022 | 08:59 AM
Gsvette074's Avatar
Gsvette074
5th Gear
Default Wheel size
Will the GrandSport wheel/tire fit in the rear wheel well of the base Stingray?
Old Oct 19, 2022 | 09:23 AM
EVRGRN's Avatar
EVRGRN
I'll take this one guys..
It will mount up, but the GS wheel/tire will stick out beyond the wheel opening on your Stingray. So basically, it will not fit properly.
The GS wheel is wider with a lower offset than the Stingray wheel. Additionally, the GS quarter panels are wider to allow for the wider wheel.
Old Oct 19, 2022 | 09:27 AM
Maxpowers's Avatar
Maxpowers
It will look like a modded Jeep with mud tires.
Old Oct 19, 2022 | 10:04 AM
squirrelchew's Avatar
squirrelchew
Hi, welcome to the forum. Search is your friend -- wheel fitment is discussed in great detail here. The latest I'm aware of was just days ago, here:
https://www.corvetteforum.com/forums...post1605772159
Old Oct 19, 2022 | 10:21 AM
Gsvette074's Avatar
Gsvette074
5th Gear
thanks.... thought that was the case. Have had c4 and c6 GrandSport and I like the traction so it seems the solution is the conversion kit listed elsewhere here on the forum. Thanks again!
Old Oct 19, 2022 | 11:03 AM
EVRGRN has provided the right advice - the rear GS wheels will stick out past the wheel well on a narrow body car.
Old Oct 19, 2022 | 11:35 AM
EVRGRN's Avatar
EVRGRN
Bear in mind that you can still fit wider and stickier tires on the back of a C7 Stingray, though you'll need correctly sized wheels.
Old Oct 19, 2022 | 11:39 AM
squirrelchew
Keep in mind that putting on wider tires doesn't necessarily mean more traction. Unless you're driving on 70°F sunny days only, you'll see some downsides over the 245/285 setup.
Old Oct 20, 2022 | 11:25 PM
Avanti's Avatar
Avanti
Fortunately, NO... as stated. And, that's a good thing since the wide-body (GS & Z06) OEM wheels are cheap junk--check the cracked and bent wheel thread that's always on the front page here.
Old Oct 21, 2022 | 01:16 AM
HOXXOH's Avatar
HOXXOH
Short wide tires are good for lateral traction and car shows, but tall narrow tires work better for forward traction. It's all about the footprint. Pick your poison.
To Wheel size
