I have a 17 stingray A8. Car runs perfect at idle and cruising speeds and through 1st gear, every gear after that at wot the car breaks down and hesitates right before and after shifts. It throws a blinking cel light that goes away. Comes back a cylinder 7 misfire. Changed all plugs and most plug wires and I even changed out the coil pack for cylinder 7. Still has blinking cel light, And breaks down still at wot. Any ideas? Car ran perfect with a couple mods and a tune before. until I recently decided to switch it over to e85 and I happened to put really trash e85 in the car and it went down hill from there. Tried switching it back to 93 and it still pops the blinking cel light.
have you run through the tank of 93 yet or are you on some mix of garbage e85?
could also be high water content in that e85 that clogged your fuel filter, too. worth checking. either replace the filter or, instead of throwing parts at an undiagnosed problem, check the fuel pump flow rate. should be a spec out there somewhere for how much it should push over a certain amount of time.
Have you thought about taking the car to a local auto parts store and having them run a scan to see what codes may be set? Many of the stores will run the scan for no charge.
Yeah I’m on my second tank of 93 and I also put a bottle of iso heat in there to evaporate some of the water that might of been in the tank.
that's... not what isoheet does, at all. isoheet is mostly isopropyl alcohol -- somewhere between 75% and 99.8%, in fact. it's not doing anything really helpful in temperatures above -30°F. the ethanol content in your fuel is pulling the water into solution above those temperatures.
that said, your fuel filter is designed to separate water out of fuel. if your garbage e85 had a ton of water in it, that'd do it.
but we're getting ahead of ourselves here. what was trash about the e85 you put into it?
Wires look similar length so I would have swapped coil and wire with another cylinder and cleared the code to see if it comes back. IF it does, the problem isn't in the coil or wire. It should only migrate to the other cylinder if it is swapped and faulty. How is the plug? If that isn't it, I would check compression because the next thing I look at is the injector. Crap could be in the basket filter if there is one or in the injector pintle.
But isoheet is also used to evaporate some water from the tank correct. The content was reading around e20. The only reason I knew that is because I took it to my tuner and had him look over everything cause I though something was off with the tune. But everything seem to be good tune wise.
I changed all the plugs and most wires and I even changed cylinder 7s plug wire a couple times and I changed out the coil pack also and the cel code still came up as cylinder 7 misfire.
no, isoheet is pulling the water into solution. no evaporation is happening.
if you were getting e20 from an e85 labeled pump and are in the US, that's.. a problem. last I checked, e85 must be between e50 and e83 according to... I believe federal law?
unless you filled up at Billy-Bob's Budget Gas and McDonald's, I would question your flex sensor before questioning the fuel. if the flex sensor is reading incorrect ethanol content and applying a trim that's different to what the actual fuel is, that'll cause some fun problems. with your 93AKI you should be seeing about E10 on your sensor. maybe give that a check to rule it out?
Leave McDonald's out of this. I'm having McRib for lunch. I'm lovin it.
Let's say you are right. Why 7 and not the rest of the injectors?
Yeah, a wonky ethanol content reading would probably show up as random misfires, you're right.
My original idea is that cylinder 7 could be end-of-line on the fuel system, but after looking up what I could find, it looks like both cylinders 7 and 2 are the furthest away from the fuel pump. Still not unreasonable to see 7 (or 2) misfiring first in a starvation scenario, which goes back to the waterlogged fuel filter theory, but a bad flex sensor trimming should be hurting all cylinders.
No I filled up at a racetrack 😂. I understand that, but do we actually know 100 % what kinda fuel we’re actually getting out of the tanks all the time. Just joking but on a serious note.
I also turned the flex fuel sensor off and running old tune with straight 93 and it’s still throwing the code.
so I don’t believe the flex fuel sensor is a problem.
Lots of moving parts here???
Get code reader and read codes- check online as to what they mean?
Quit putting e85 gas in the car. I am not a fan of running anything but 93 oct in any of my cars. In some cars you'll get better mileage with 93 which will off set some added cost? but it will burn cleaner too.
Sounds like disolved water in the e85 fuel. If so it will take time to get it out.
Corvettes are wierd animals concerning plugs, wires and coils. I changed all my Plugs in my 2007 Z06 to hotter plug and it threw codes- changed back to oem plugs no problem. If your changing plug wires I do all at same time. My point is that corvette can be temprimental ????
I think that if you have a tune you can run E85 with the right mods.
He has run 2 tanks of 93 in it already. Besides, why 7 and not the others if it is a fuel problem?
If you change the specs *****-nilly, any car can be a problem. Corvettes are not special in this.
yes, that's why I pointedly asked if you went to a sketch-*** gas station.
it's why they are regularly tested, stickered for compliance, and fined/shut down if they are noncomplaint.
it's why you go to top tier certified gas stations, because if they ever serve fuel that is not inclusive of the advertised detergent package and the advertised AKIs, they get heavily fined or shut down.
