Pedal Commander
The simple and free solution is to push the accelerator down further if you want more power.
You can buy a pedal commander if you'd like, but all it's doing is pushing the accelerator pedal down a little further for you electronically.
Lag is a delay, and a throttle controller does not change the amount of delay between throttle input at the pedal and throttle change at the throttle body. They simply cannot do this.
All they do is remap your throttle. A given input at the pedal, say 50%, should be a given output, say 35%, at the throttle body. You may want it to be 65% instead. Or 50%. Or 100%. They don't improve performance, they don't "open the throttle faster", they simply tell the ECU that you are pushing the throttle pedal a different amount than you actually are.
With and without a throttle controller, stomping on the pedal to the floor is identical. You cannot give it more than 100% throttle. The throttle controller can only send a 100% throttle signal. There isn't an extra message, like "100% throttle, but do it faster please" -- the signal being received by the ECU, which ultimately drives the throttle body, is an amount of throttle. There is no mechanism by which to increase the speed at which the throttle plate physically opens that a throttle controller can adjust.
WOT is "wide open throttle"
WOT is completely and entirely unchanged by your throttle controller.
You're saying it is changed by the throttle controller.
It very, very much is not.
There is zero difference between WOT with and without a throttle controller. Soler even explains how their controller works and very explicitly states that it just opens the throttle more for a given pedal input, and that there's no additional power to be realized. Your throttle body is opening 100% -- you cant say "yeah but open it even more fully" when it's already fully open, which is what you're suggesting the throttle controller does.
I know how the system works. I've adjusted throttle mappings before -- and when I can't edit them in the ECU, I just push the pedal an appropriate amount for the power I wish to have delivered.
The hierarchy is throttle pedal -> throttle controller -> ECU -> throttle body. Soler even has a big ol' picture diagram explaining this.
Any lag (meaning delay measured in units of time such as milliseconds between pedal input and power output, if this is not what you mean to imply, stop saying it) in opening the throttle body is introduced by the ECU or the throttle body motor itself. Your little box is just saying "I hit the pedal harder" to the ECU. The exact same effect can be achieved without a throttle controller if you push the pedal down further.
If you still think that WOT is different with a throttle controller, then there isn't much more to discuss here beyond the promise that I'll paypal you $500 to provide empirical evidence of this claim.
When you actually drive a car with a throttle controller then come back and let us know. If you say there's no difference (and it is significant) then you're lying. Peace out brah...
