Alignment Question
Old Dec 26, 2022 | 09:22 PM
fritz1990's Avatar
fritz1990
Default Alignment Question
Can you align the front end before you put on new tires? Mine are worn bad on the inside and my tires won’t be here till after the 1st of the year. I have an appt. tomorrow.
I did a search on alignment specs and what I found for max tire life was -0.5 camber and 0 toe for street only use. I don’t track my car, daily driver.
Regards, Jeff
Old Dec 26, 2022 | 10:19 PM
eseibel67's Avatar
eseibel67
Alignment should be done with new tires. How far is the drive from new tires to alignment? I also have the cords showing through the insides of both original front tires after 28k miles but it drives dead straight. I plan on short drive to alignment place with new tires for a more road friendly alignment than stock for longer tire life.
Old Dec 26, 2022 | 10:29 PM
RacerRik's Avatar
RacerRik
I think the OP is asking if he can get the alignment done now and get new tires installed later and the answer is yes. You can certainly get it aligned at any time. Alignment has nothing to do with the tires except determine how they wear. So if you get it aligned now, you do not need to get it aligned again once you get the new tires.
Old Dec 26, 2022 | 10:52 PM
fritz1990's Avatar
fritz1990
Thank you! I thought so but wanted to check. It drives like an arrow but the insides are smooth and almost new on the outside. I’ve only had the car for 2500 miles and was shocked to see the wear. Thanks again!
Regards, Jeff
Old Dec 26, 2022 | 10:57 PM
squirrelchew's Avatar
squirrelchew
^^^ this.
Old Dec 26, 2022 | 11:02 PM
fritz1990's Avatar
fritz1990
Originally Posted by squirrelchew
^^^ this.
Yes that is what I was asking.
Regards, Jeff
Old Dec 28, 2022 | 01:06 AM
RacerRik is right on the alignment - you can do it now and then install new tires.
Old Dec 28, 2022 | 09:44 AM
CraigStu's Avatar
CraigStu
Yes.
Old Dec 28, 2022 | 11:51 AM
fritz1990's Avatar
fritz1990
Here is my before and after alignment specs. Getting New tires Friday.
Regards, Jeff
Old Dec 28, 2022 | 12:50 PM
wrecker3's Avatar
wrecker3
Did the Shop have a Rear Caster tool ? If Rear Camber was Adjusted it will Change Rear Caster. They have to be Adjusted Together. Alignment Machines Can Not Measure or Display Rear Caster
Old Dec 28, 2022 | 01:23 PM
c5arlen's Avatar
c5arlen
Naw... Just buy new tires every year.
Old Dec 28, 2022 | 07:56 PM
fritz1990's Avatar
fritz1990
I just had the front done. My rear tires are wearing just fine. It sure does drive a lot better!
I am aware of the rear camber/caster settings.
Regards, Jeff
To Alignment Question
