C7, P0700 check engine code
Old Jan 16, 2023 | 11:36 AM
jenninpg's Avatar
jenninpg
7th Gear
Default C7, P0700 check engine code
Is it safe to drive my C7 with a P0700 check engine code in manual about 40 miles to a dealer without risking damage?
Thank you
Paul J
Old Jan 16, 2023 | 11:58 AM
SILENT BOB's Avatar
SILENT BOB
From: Tank sticker? I ain't got no tank sticker! I don't need no tank sticker! I don't have to show any stinking tank sticker!
Thank you
Paul J
Appears to be a transmission fault code. How many miles on the car? Did it have triple flush?
Old Jan 16, 2023 | 12:08 PM
jenninpg's Avatar
jenninpg
7th Gear
Default Silent Bob
Thanks for reply. I have 42,500 miles. Torque converter was replaced at 20,000 so fluid was replaced at that time. Even though temp was in the 20's and the car wasn't driven hard the differential pump appeared to run a bit longer than usual after I parked and shut the engine off.
Old Jan 16, 2023 | 10:11 PM
Dcasole's Avatar
Dcasole
P700 code is a generic transmission code request to light the CEL , There is another code in the TCM, it will be 700 series code , if your code reader does not read it take it to any auto supply , they will read the code . Then post it here
Dave
Old Jan 16, 2023 | 10:13 PM
jenninpg's Avatar
jenninpg
7th Gear
Thank you. I'll try and get that code.
pj
Old Jan 16, 2023 | 10:26 PM
Dcasole's Avatar
Dcasole
Thank you. I'll try and get that code.pj
if i had to guess, it's a p0711 code , which is a short in the trans harness temp sended harnesses , there is aTSB . If your trans temp guage is barely going above then the harnesses are your problem
Old Jan 16, 2023 | 10:30 PM
jenninpg's Avatar
jenninpg
7th Gear
Thanks. I'll check the temp. Hadn't thought of that mainly cause it was mid 20's yesterday but I will now.
Old Jan 16, 2023 | 10:45 PM
Good luck - please post up what you find out.
Old Jan 17, 2023 | 07:15 AM
Dcasole's Avatar
Dcasole
Yep had to change mine out , TSB says to change out both harnesses out but the upper required removing the valve body and a bunch of other things . I just replaced the lower which contains the temp sensor. Dealer wanted over $700 to replace . I ended up doing it myself in 2 hours with just the cost of the harness , transfluid and filter Dave
Old Jan 17, 2023 | 11:31 AM
jenninpg's Avatar
jenninpg
7th Gear
Ok. Thank you for the input. I'll be trying to get the sub code asap.
pj
Old Jan 17, 2023 | 01:27 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Thank you
Paul J
This is certainly not what we like to hear, jenninpg. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your vehicle. To do so, please send an email to socialmedia@gm.com with ATTN: jenninpg/Corvette Forums in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
Old Jan 17, 2023 | 04:32 PM
Dcasole's Avatar
Dcasole
Originally Posted by Chevy Cust Svc
This is certainly not what we like to hear, jenninpg. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your vehicle. To do so, please send an email to socialmedia@gm.com with ATTN: jenninpg/Corvette Forums in the subject line. Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement. Privacy Statement | General MotorsYour privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.www.gm.com
I dont know why they do this its not like they do anything about it , its a known problem that unusually is not covered under warranty unless you have an extended powertrain and in that case you dont need then , what are they going to do , setup an appointment for u ?
Lets ask them to take care of our shudder issues and cracked wheels
Dave ​​​​​​​
To C7, P0700 check engine code
