Wrong differential oil
Old Feb 9, 2023 | 01:40 PM
tariqc7's Avatar
tariqc7
3rd Gear
Default Wrong differential oil
Guys
I need help!!
I went to a poor service center where they changed my differential oil with ACdelco 75W90 GL5 which I came to discover it’s not the GM recommended part number for my 2016 C7 corvette when I drive slow speed and I turn full right or left I hear a weird sound in the rear.
IT s it too late for my differential or I can replace it with the recommended fluid and the noise will go away ?
Popular Reply
Feb 9, 2023, 02:32 PM
76-Vetteman's Avatar
76-Vetteman
Get it filled with the correct fluid, put some miles on it and bring it up to operating temperature, and then change it again. You should be ok.
Old Feb 9, 2023 | 02:04 PM
robert miller's Avatar
robert miller
Default ttt
Originally Posted by tariqc7
Guys
I need help!!
I would get that out of it and put in the correct stuff and hope it didnt do any damage. But it may be making that sound only at those times and has not done nothing as of yet.. That is my 2 cents on just to hope the chg will do the correct job for you. Robert
Old Feb 9, 2023 | 02:16 PM
tariqc7's Avatar
tariqc7
3rd Gear
Fantastic
shall I drive it to the service center or request at towing service?
Old Feb 9, 2023 | 02:32 PM
76-Vetteman
Old Feb 9, 2023 | 02:35 PM
tariqc7's Avatar
tariqc7
3rd Gear
Got u and thanks for the reassurance
Is it safe to drive it now to the service center or should I request towing service as it’s around 10 miles from my home to the service center!
Old Feb 9, 2023 | 03:00 PM
ErnieN85's Avatar
ErnieN85
Drive it there
Old Feb 9, 2023 | 03:07 PM
Flattman's Avatar
Flattman
And by putting miles on it, I'd think no more than 20 miles at operating temperature would be necessary before you change it back out again.
Old Feb 9, 2023 | 03:13 PM
orca1946's Avatar
orca1946
And make them pay for the change and fluid this time!
Old Feb 9, 2023 | 05:28 PM
96GS#007's Avatar
96GS#007
Sounds like that fluid doesn't have the limited slip additive in it and you're hearing the clutch packs. Have them change it. It may take some figure 8s in the parking lot and a few miles for the new fluid to get rid of the pops and noises.
Old Feb 9, 2023 | 10:17 PM
Avanti's Avatar
Avanti
Right, 96GS#007 stated the most likely scenario. Good luck.
Old Feb 9, 2023 | 10:58 PM
I agree with having them change the oil with the right stuff this time. If there is any damage, they should pay to have it fixed.
Old Feb 10, 2023 | 10:14 AM
bikemiser's Avatar
bikemiser
I think the car will be fine to drive to the dealership to get the fluid changed
Old Feb 10, 2023 | 12:36 PM
kaplana08's Avatar
kaplana08
My Corvettes Only Shop uses Mobil 1 Diff. Fluid instead of the GM stuff. They tell me it is much better. Works beautiful in my C7.
Old Feb 10, 2023 | 01:27 PM
vettetwo's Avatar
vettetwo
I would call the service center and ask them if they want to pay for towing for them to correct the error, or have you drive it in. That will show them you are serious about them correcting their error and any damage caused by driving any further is on them.
Old Feb 10, 2023 | 05:58 PM
CraigStu's Avatar
CraigStu
Just drive it to them and get it changed. Then you need to drive it for a while before changing it again. It is also possible that you won't need a second change. Think about a typical clutch pack lim slip diff. To simplify a little you have a stack of discs, maybe 12 of them. Every other disc is connected to the left axle. The ones in between are connected to the right axle. These discs are pushed tightly together so they will slip in relation to each other only under certain conditions. What you are hearing is the discs trying to slip but they have the wrong fluid to make that slip a smooth process. The reason I say drive it for a while is it will take some time for the old fluid to work out from between the discs and the new fluid to work in. BTW, like kaplana I use Mobil 1 LS 75-90 in mine. But in your situation I would go w/ whatever GM recommends.
Old Feb 11, 2023 | 05:02 PM
HOXXOH's Avatar
HOXXOH
In the future, if you need someone else to do maintenance on your car, purchase the parts and/or fluids yourself and simply pay them for the labor. Finding a place that'll let you watch or assist is a bonus, to be assured that it's done correctly and with your supplied products. Creating a relationship with an independent shop and financially compensating them well, will pay off in the long run.
Old Feb 11, 2023 | 05:21 PM
Widgeon5's Avatar
Widgeon5
Guys
I need help!!
Do you have the electronic limited slip (ELSD)? I'm working from memory here, but I recall a posting (maybe from Bill Dearborn) that only the old-style mechanical limiited-slip differentials (as in the base C7) actually require the friction modifier. My memory could be faulty.
Old Feb 11, 2023 | 08:45 PM
fritz1990's Avatar
fritz1990
I just sent an email to Chevron and they recommended their Havoline Full Synthetic LS 75-90 for my diff. Will pick it up Monday at my local supplier.
Regards, Jeff
To Wrong differential oil
