Injector cleaner
Old Feb 20, 2023 | 10:32 AM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Default Injector cleaner
Anyone run any kind of fuel injection cleaner like Sea Foam or….? How often should the injectors or fuel systems in general be cleaned/serviced?
Popular Reply
Feb 20, 2023, 11:28 AM
I run a bottle of Techron Concentrate 1-2 times a year in my car.
Old Feb 20, 2023 | 11:28 AM
Old Feb 20, 2023 | 11:49 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I use Techron a couple times a year as well.. good stuff
Old Feb 20, 2023 | 08:44 PM
BluRace's Avatar
BluRace
i have used Techron in all my vehicles, highly rated, however,
unless your injectors NEEDed to be cleaned
you probably won't notice any difference.
Old Feb 20, 2023 | 09:17 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I use a gasoline that has injector cleaner in the gas. I've never had an injector plug up since I've been driving FI cars. I just don't see how those injector cleaner manufacturers have been able to stay in business without me using their products.
Elmer
Old Feb 20, 2023 | 09:40 PM
sjw91's Avatar
sjw91
Your owner's manual recommends using Delco Fuel System Cleaner (re-labeled Techron) once a year, unless you're using Top Tier gas regularly.
Old Feb 20, 2023 | 09:43 PM
BluRace's Avatar
BluRace
99% of my fuel is from Costco
which is Top Tier,
so i probably wasted my money buying the Techron.
oh well
Old Feb 20, 2023 | 10:38 PM
jdaniels138's Avatar
jdaniels138
Veteran: Marine Corps
I use Redline fuel system cleaner before each oil change, which is about once year.
/JD
Old Feb 20, 2023 | 11:12 PM
jlbruggeman's Avatar
jlbruggeman
Another dedicated Techron fan-All my vehicles, from Corvettes down to Harley and riding lawnmower!
Old Feb 20, 2023 | 11:27 PM
aklim's Avatar
aklim
Elmer
I have never tried it on these injectors yet so I don't know. The Bosch style injectors do pick up some varnish that I can see. I have gotten the before and after results from FIC which I verified on an actual injector bench. There was some build up that got cleaned by FIC and others like them. Also it gets the basket filter changed
If you are NOT being facetious, the answer is simple. Cheap snake oil and people will say "What have I got to lose?" so they buy it. If they feel a difference, they will be back. If not, there are more suckers down the line.They don't have to make a ton of money off each one. Easier to milk the suckers by volume, of which there are plenty.
Old Feb 21, 2023 | 12:16 AM
RockyL32's Avatar
RockyL32
Thanks for all the responses. I don’t expect to feel or hear a difference. The goal is to keep them clean regularly so there is no difference. I normally use a “top tier” fuel but I’m sure there will be times when the first station I see gets my business. I will throw some Techron down the pipe once or so a year. At worst it probably does no harm, at best it does what it promises.
Old Feb 21, 2023 | 03:55 AM
jimmbbo's Avatar
jimmbbo
An additional benefit reported in several Techron threads is that it helps keep the fuel quantity sending unit clear of sulfur, which causes erroneous readings...
Old Feb 21, 2023 | 06:45 AM
mdformula350's Avatar
mdformula350
another vote for Techron , plan to do it once a year prior to oil change
I mostly use shell 93, still use it for maintenance purposes.
I bought a few Chevron Techron Concentrate Plus, 10 oz bottles, i need to recheck my supply.
appears the price like everything else went up drastically to double what I paid 2 years ago.
Old Feb 21, 2023 | 07:35 AM
rheavn's Avatar
rheavn
I use Top Tier fuel as often as possible and Techron 2 or three times annually.
Old Feb 21, 2023 | 08:52 AM
aklim's Avatar
aklim
Gasoline does a good job for me without any snake oils.
Old Feb 21, 2023 | 10:34 AM
Maxpowers's Avatar
Maxpowers
I just run Top Tier gas (Costco).
Old Feb 21, 2023 | 10:44 AM
eboggs_jkvl
Moderator emeritus
Nope, I don't believe I need the techron to keep my injectors clean.
Elmer
To Injector cleaner
Old Feb 21, 2023 | 11:23 AM
aklim's Avatar
aklim
Elmer
I don't know yet. I know my L98 style injectors pick up varnish based on the before flow numbers compared with the after cleaning flow numbers. I will test the GDI injectors and see when the time comes. At this point, I will know, not believe or guess.
Old Feb 21, 2023 | 12:41 PM
Gixxerman's Avatar
Gixxerman
Moderator
I am required to have a use for little plastic funnel once a year to keep plastic in good condition and properly justify it's position in my Corvette's cubby compartment.
Old Feb 21, 2023 | 12:52 PM
aklim's Avatar
aklim
I thought it was a training beer funnel for people who start drinking?
