What are the common problems?
I am getting overwhelmed with negative opinions and experiences now.
The C7 isn't perfect. But it's also not a complete piece of crap. I'd be disappointed if I had ALL those problems, but I don't, and I doubt anyone else has ALL of them.
If you pick your vehicle carefully you can avoid a lot of the problems. For example, avoid the 3LT and you avoid the dash issue. You said you're looking for an automatic, so make sure it's had a triple flush, and ideally one that is either a) low miles or b) spent most of it's life with a Range device to disable the AFM and you avoid all the AFM problems. Get a good PPI so you don't buy someone else's torque tube problem (coupling and bearing issues should be easy to pinpoint).
You're not looking at GS/Z06 so you can ignore all the overheating and rim issues.
It seems the main undetectable and unpredictable issue is the infotainment bonking out, as there seems to be a supply-side issue with GM to get new units. These cost what ... $2k to replace? We're talking about $40k+ cars here so that price shouldn't be a complete showstopper. There is an Android replacement unit but then you lose the hidden cubby and car-specific settings.
Personally, I'm coming the BMW, Audi and Ducati world so I'm used to living with the potential for frequent and expensive repairs (not to mention maintenance). By comparison, I find the C7 to be a simpler and more reliable machine. Maybe you don't see it that way, and have a lower tolerance for problems. I get that, and I hope you can find what you're looking for.
I bought the car with more than 50k miles on it, and I'm probably the 2nd or 3rd owner.
The Torque Tube problem was taken care of by the dealer.
I later found cracked & bent wheels, and a neglected front alignment.
The black screen of death was brought back by wiggling a few plugs.
All my other problems were caused by hitting a large piece of debris on a dark interstate.
This is my 4th Corvette.
What a nightmare...
I just got a 2015 z51 supercharged by ECS and it's amazing. Clean, perfect, no issues with it at all. Engine sounds like a sewing machine.
The C7 is a great car. There were more than 180,000 C7s built so there's plenty to choose from in the used-car market. A VIS report will tell you if certain warranty work was performed to take care of the torque tube or shudder problem, keeping you from an out-of-pocket expense. A CARFAX report might also disclose this.
Shop around for a 2018 or 2019 C7 to get the latest upgrades, including the front camera. And, buy a Range device to prevent AFM lifter issues if you get an A8. I have a 2019 2LT GS. Yes, I replaced my wheels. Yes, I replaced my summer-only tires. Other than that, no problems or issues. This is my 2nd Corvette, joining a C3 that I bought new and still drive. The C7 is a great car.
