Lighter Socket
Old Mar 5, 2023 | 11:54 PM
SixGunOutlaw's Avatar
SixGunOutlaw
5th Gear
Default Lighter Socket
I bought the official Corvette C7/C8 battery tender (Made in China FFS) but keep getting a blinking red light. I reset it like 5 times. Is there a setting I need to use to activate the cigarette lighter? It always resets to the lowest charge level. Do I need a new battery?
Old Mar 6, 2023 | 12:25 AM
Buddhaman's Avatar
Buddhaman
You’re plugging it into the socket in the trunk, right?
Old Mar 6, 2023 | 01:54 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
The socket by the Shifter is not active when the engine is off. The one in the trunk is.
Old Mar 6, 2023 | 08:38 AM
Zjoe6's Avatar
Zjoe6
Moderator
Yes use the rear cigarette lighter.
Old Mar 6, 2023 | 08:49 AM
What the others have said - plug the tender into the socket located on the passenger side in the trunk area.
Old Mar 6, 2023 | 09:01 AM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
Mind would loose a good connection, just from vibrations in the area in the garage.
I had to bend the prongs on the end of the male connector that plug into the trunk socket.
Old Mar 6, 2023 | 11:07 AM
Flattman's Avatar
Flattman
Not sure if yours has it, but in some cigarette lighter adapters there is a fuse inside them. If so, unscrew the tip of it and have a look just to be sure it's good.
Old Mar 6, 2023 | 07:32 PM
Avanti's Avatar
Avanti
He's new. And, just plugged-in to the wrong socket.
Old Mar 7, 2023 | 12:31 PM
Mike Mercury's Avatar
Mike Mercury
there's a fix for that:
https://www.corvetteforum.com/forums...lways-hot.html
To Lighter Socket
