Mild to Wild question
Old Mar 11, 2023 | 08:40 PM
jol's Avatar
jol
Default Mild to Wild question
Hi,
i’ e been a CF member for years and on my 9th Vette. I recently bought a M2W for my 7200 mile C7. I loved it on my C6 427.
question: since I can set the tone of the exhaust on the infotainment screen, is the M2W necessary.
Thanks as always. You are all very much appreciated, especially the Mods.
Old Mar 11, 2023 | 11:05 PM
Kehraus's Avatar
Kehraus
I programmed the buttons on the visor to change mine.
Honestly I rarely change it.
Old Mar 12, 2023 | 12:04 AM
Honestly, I can't see where the M2W would do a whole lot more than you can accomplish from the Infotainment screen. However I have never owned a M2W product so perhaps I am missing something.
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I have the switch I built through the forums, I have it on my Homelink buttons as well..
Old Mar 12, 2023 | 12:16 AM
Goat 2 Vette's Avatar
Goat 2 Vette
How do you do that? On the 14 & 15 I don't think you can set the exhaust in the infotainment screen. In fact I know you can't.
Old Mar 12, 2023 | 12:17 AM
Goat 2 Vette
Originally Posted by jol
Hi,
Why did you get rid of the C6 427? I'm thinking of buying one.
Old Mar 12, 2023 | 07:22 AM
Catfish4818's Avatar
Catfish4818
I don't know about '14s, but on '15s the exhaust tone is adjustable only when the car is equipped with the optional NPP exhaust.
Old Mar 12, 2023 | 09:03 AM
GSRoadster's Avatar
GSRoadster
I have the M2W on my 2017 GS Vert M7 and also programmed into two of the Garage Door Opener buttons - works perfectly. When I bought the car a few years ago, I noticed that, at least with the M7, there was an RPM range (1300-1500, I think), where, even if the NPP exhaust was set to "Track", it would still change between loud and much less loud as I throttled in and out of that range. It was annoying and sounded strange since that's a pretty common RPM to drive in and out of. If I pulled the NPP fuse, the problem went away, but I lost control of the exhaust.
I learned here that GM had programmed some quieter ranges into the exhaust, regardless of screen settings, to help them meet noise requirements for the car/fleet. In other words, even in Track setting, the exhaust baffles are not always open. I think I read that the automatic transmission cars are programmed somewhat differently, so YMMV. M2W solves the problem and gives you instant choice of wide open or stealth with a quick push of the button - way faster than scrolling through screen settings. It's really nice to be able to change that quickly when you're out for a ride and want to hear the sound, but don't want to PO the neighbors when you turn onto a residential street.
Old Mar 12, 2023 | 11:32 AM
GSCE#456's Avatar
GSCE#456
that is because you are supposed to set it to “Stealth”. That way when M2W is activated the valves are wide open 100% of the time. When you press the button on the M2W it will then go into Stealth mode to quiet down.
Old Mar 12, 2023 | 11:35 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
14s can't control the exhaust like the later models, maybe the 15s too. I have the M2W and programmed the visor. Left button is loud, right button is quiet.
Elmer
Old Mar 12, 2023 | 11:38 AM
^&right's Avatar
^&right
I have NPP on my '15. How do I set up my homelink to shortcut stealth to Track modes??
Old Mar 12, 2023 | 11:45 AM
eboggs_jkvl
Moderator emeritus
THe M2W comes with FOBs. You pair a FOB to the homelink as open and close. Someone built a DIY button or kit to operate the NPP valves. Here is that information: https://www.corvetteforum.com/forums...e-control.html
Elmer
Old Mar 12, 2023 | 11:59 AM
vern1's Avatar
vern1
Didnt we just go through this question a couple of days ago.....
Pull the fuse. Honestly, going through any neighbourhood at low throttle is not going to **** off anyone because its just not loud - there is a slightly lower tone but its not loud. Now at WOT it makes a difference but no one does that (well maybe someone does) .
I live in a neighbourhood, as presumably many of us do, and have never had anyone give me the stink eye let alone come running out shaking their fist at me (and I have cut out the cats so its even louder than normal)
Old Mar 12, 2023 | 12:23 PM
jol's Avatar
jol
Default M2W visor control
Hi, can you please explain how you “connected” the M2W control to the visor? Thanks very much.
QUOTE=eboggs_jkvl;1606377713]14s can't control the exhaust like the later models, maybe the 15s too. I have the M2W and programmed the visor. Left button is loud, right button is quiet.
Elmer[/QUOTE]
Old Mar 12, 2023 | 12:26 PM
jol's Avatar
jol
I was foolish. I ven traded it in which cost $$$. The reason was I was concerned about the potential valve drop. I had 9,000 miles !!!
I’m also looking to get another one.
Old Mar 12, 2023 | 12:28 PM
jol's Avatar
jol
Hi,
Thanks everyone. Great information. G-d, I love this place!!!!!
Old Mar 12, 2023 | 01:35 PM
Bill Dearborn's Avatar
Bill Dearborn
M2W won't work on a car that doesn't have NPP.
Bill
To Mild to Wild question
Old Mar 12, 2023 | 02:23 PM
Gixxerman's Avatar
Gixxerman
Moderator
True, I built my own. The M2W switch requires cutting, running wires, locating a box.. etc. etc. Wanted mine to be hidden (Our built unit fits under fuse cover and not visible removable in like 5 seconds) .. Your controlling the fuse remotely basically, and not the infotainment settings (Unit you build here has remotes to program with) If you have ability to set stealth mode, then when you hit button it will go quiet for you.
https://www.corvetteforum.com/forums...-how-to-5.html
Old Mar 12, 2023 | 02:44 PM
eboggs_jkvl
Moderator emeritus
Elmer
[/QUOTE]
YOu program the visor to operate your garage door? You program the 2 remaining buttons to do the open and the close of the NPP valves. Same instructions to program. You push the open button for one button and the close button for the open button.
YOU MUST have NPP exhaust to mess wirh this process.
Elmer
Old Mar 13, 2023 | 10:37 AM
JonMN's Avatar
JonMN
I started using the M2W, via programmed visor buttons, but then I found that Wild was really not very loud anyway. So I pulled the fuse and just leave it "wild."
PS: On a humorous note, our young neighbor boy, who loves vettes, used me as a weather forecast back when I was working. If he heard me leave for work in the vette he knew it was a good forecast for the day!
