Need alignment
Old Mar 24, 2023 | 08:36 AM
Tinkertech's Avatar
Tinkertech
Default Need alignment
My 17 1lt is completely stock need an alignment.
I live in the Plano, Frisco, Allen Texas area.
I am unable to leave the car anywhere because its my only transportation.
Every place I call says leave the car for weeks, no can do.
Does anyone know of a really good alignment place that knows how to properly align a C7 while I wait on it?
Old Mar 24, 2023 | 09:22 AM
96GS#007's Avatar
96GS#007
If you're willing to drive, Doghouse Performance in Cresson is lights out and you can book a time online. I was at MSR-Cresson yesterday and they aligned mine. They're on the MSR-C property so I literally went from the shop and onto the track and the setup was spot on. Adam did an awesome job. It's a small shop but don't let that fool you. Adam definitely knows what he is doing. I live in Prosper FWIW.
Big Shout-out to @GSpeed for their assistance as well. Louis and Paul are phenomenal to work with and I appreciate them letting me bend their ears. My car will be headed to their shop in the very near future for some work.
Old Mar 24, 2023 | 11:27 AM
JonStone44's Avatar
JonStone44
Not quite Plano/Frisco/Allen, but I have had some luck at Lakeside Chevy in Rockwall; I deal with Chap and Michelle...you may even get lucky and get a loaner, if that would help you.
Old Mar 24, 2023 | 01:51 PM
Tinkertech's Avatar
Tinkertech
Anyone have any luck in local dealers a bit closer?
Old Mar 24, 2023 | 02:41 PM
GSpeed's Avatar
GSpeed
Supporting Vendor
BSP Motorsports in frisco, (469) 731-5887 talk to or ask for Brandon, hes the owner. He does great work, unsure if he will let you wait. But, hes close enough (just west of DNT/Little elm*) that you could uber home.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
Old Mar 24, 2023 | 02:51 PM
Bills17n72's Avatar
Bills17n72
wow good luck
Old Mar 24, 2023 | 07:52 PM
Flattman's Avatar
Flattman
Leave a Corvette for weeks for an alignment?? That seems absurd and they should be able to manage their appointment schedules a bit better than that window. I hope you find the right shop, wish I could help.
Old Mar 25, 2023 | 07:35 AM
449er's Avatar
449er
CF Community Team
They need your car for weeks to do an alignment?
Old Mar 25, 2023 | 10:33 AM
Tinkertech's Avatar
Tinkertech
Quote, you need to get in line.
Appointmens set weeks in advance
Need your car on the lot to be in line.
Old Mar 25, 2023 | 12:53 PM
ZMMMMM's Avatar
ZMMMMM
I presume you called Classic Chevrolet. I once considered http://texastrackworks.com/, which is south of downtown FW, but decided to let my tires ride #punintended. My settings are all green, but my 4 tires fail first on the inside of the tire.
I'm not sure if they have the tools to measure/adust the rear caster.
Old Mar 25, 2023 | 02:27 PM
TxLefty's Avatar
TxLefty
Huffines in Plano can do it for you. Ask for Keith in Service. You'll just have to ask how long the wait will be. I just usually leave mine for the day.
Both Huffines and Classic will set your rear caster to spec.
Old Mar 25, 2023 | 07:51 PM
aklim's Avatar
aklim
Did you ask to see the tool? I would before I make any appointment.
Old Mar 26, 2023 | 07:41 AM
Tinkertech's Avatar
Tinkertech
Did Huffines do a good alignment for you.
Steering wheel straight, no pulling, all the number set as you wanted?
Were you able to 'wait' on the car while the work was done?
Old Mar 26, 2023 | 10:54 AM
TxLefty's Avatar
TxLefty
It was perfect as nearly as I could tell. My memory is that I scheduled out a couple of days from when I called. The timing isn't perfect, so you may end up sitting around for a while. Talk to Keith Overturf and find out the particulars.
Old Mar 13, 2024 | 03:31 PM
jdaniels138's Avatar
jdaniels138
Veteran: Marine Corps
Had mine done today at Huffines in Plano. Was in and out in about an hour. I set the appointment about a week out.
They didn't leave the before and after settings sheet in the car, so I don't know what was changed. The tires I recently took off were worn more on the insides of the fronts, not so much the rears.
/JD
To Need alignment
