Engine knocking
Old Mar 28, 2023 | 02:27 PM
Wbstead's Avatar
Wbstead
2nd Gear
Default Engine knocking and oil leak
I have a 2016 c7 z06 that has an oil leak. Approximately 3000 miles ago I had the front and rear main seals replaced at a Chevy dealership. The car is still leaking oil but when I took the car to another dealership they weren't able to find the source of the oil leak. They also said that they heard a knocking noise about halfway down in cylinder number 7. The knocking noise goes away after idling for a few minutes. I've attached a video of the knocking noise. Any words of wisdom or advice is appreciated.
File Type: mov
Last edited by Wbstead; Mar 31, 2023 at 11:31 AM. Reason: To give a more detailed description of the issue
Old Mar 28, 2023 | 05:22 PM
bikemiser's Avatar
bikemiser
if you here this noise mainly under the car, it sounds to me like a flex plate rattle. Just my .02 cents.
Old Mar 28, 2023 | 05:39 PM
Flattman's Avatar
Flattman
I was wondering/thinking if they got the torque tube reinstalled correctly too. OP, how many miles on the car and is it an A8 or M7 - I can't tell from the bell housing.
I would think a catastrophic knock from the crank or a rod would result in a loss of oil pressure.
Old Mar 28, 2023 | 07:03 PM
Wbstead's Avatar
Wbstead
2nd Gear
The car has 39K miles and it's a A8.
Old Mar 30, 2023 | 10:57 AM
etaylor14's Avatar
etaylor14
If they didn't re-install the torque correctly it will eventually wipe out the rear main bearing or torque tube bearing assy.
Old Mar 30, 2023 | 02:02 PM
Goat 2 Vette's Avatar
Goat 2 Vette
Your car is leaking with 39k miles on it? That's odd..
To Engine knocking
