stingray died
Old Mar 28, 2023 | 08:15 PM
edzvet's Avatar
edzvet
Default stingray died
I have a 2016 Stingray. Last week while driving, I got a message on the dash to open and close the drivers side window, which I did. A short time later, another message for the passenger side window. I’ve never seen that before. My engine light came on and the car killed. For a short time, the emergency flashers wouldn’t work. Twenty minutes later it started, and I brought it to the dealer. Everything worked fine for the dealer, and after 3 days they gave up. They have no idea. Has this ever happened to anyone else? Thanks in advance.
Popular Reply
Mar 28, 2023, 08:17 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
How old is your battery? Check all connections on the battery including the little black wire going to ground.
Old Mar 28, 2023 | 08:17 PM
CorvetteMike2024
Corvette Enthusiast
Old Mar 28, 2023 | 10:56 PM
Good first place to start.
Old Mar 29, 2023 | 12:13 AM
HollywoodJones's Avatar
HollywoodJones
This happened to me (the window thing) and it was my battery. Replaced it and it was all good. Also a 2016
Old Mar 29, 2023 | 12:47 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Let us know how you make out
Old Mar 29, 2023 | 06:46 AM
Tony1320's Avatar
Tony1320
I disconnected my battery to install the Soler throttle body and controller. When I hooked it back up I got the same messages but none after that.
Old Mar 29, 2023 | 07:27 AM
449er's Avatar
449er
CF Community Team
As the others have posted, the battery is the culprit fir many of these odd messages
Old Mar 29, 2023 | 08:36 AM
miami08VETTE's Avatar
miami08VETTE
Old Mar 29, 2023 | 08:44 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
When you disconnect the battery for ANY reason, you MUST Re-index the windows. Refer to your owner's manual for the proper procedure for your model year. I have the 2014
2014
Window Indexing and
Express-Up Reset
Window indexing may be required if
the vehicle battery has been
recharged or disconnected, or is not
working.
Express-up and the
convertible top will not function until
the windows are reset. After battery
power is restored, a message or
code displays in the Driver
Information Center. See Driver
Information Center (DIC) on
page 5-23.
Once power is restored:
1. Close the doors.
2. Start the vehicle.
3. Hold the window switch up to the
fully closed position.
Elmer
Old Mar 29, 2023 | 01:12 PM
edzvet's Avatar
edzvet
Thanks everyone! I will check the battery and connections and let you know. I remembered that the battery was disconnected at one time not too long ago.
Old Mar 29, 2023 | 07:00 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
ALL connections must be tight and the small black wire at the negative terminal is easily broken.
Old Apr 4, 2023 | 11:12 AM
Kangarew's Avatar
Kangarew
So, how did it turn out? Bad battery or bad connection(s)?
Old Apr 5, 2023 | 07:36 PM
edzvet's Avatar
edzvet
I think my problems are more serious. The dealer can't figure it out, and now it is doing other things. The electric power steering is working when the car is off and the tail lights and headlights on the passenger side are out.
Old Apr 7, 2023 | 12:25 AM
JDMvette7's Avatar
JDMvette7
2018 C7 of Year Finalist
Did you just take the car out of storage? Is it possible a critter could have gotten to your wiring harness?
Old Apr 7, 2023 | 09:37 AM
edzvet's Avatar
edzvet
that is possible. I'll check it out
Old Apr 7, 2023 | 03:42 PM
VinceC5's Avatar
VinceC5
Replace the battery. Mine started doing that, but it showed good during testing and it had enough juice to power on lights, etc... No issues after replacing the battery and it starts much better now.
Old Apr 8, 2023 | 09:25 AM
edzvet's Avatar
edzvet
is it possible that the battery will have 12.8 volts, pass a load test and still be bad?
To stingray died
Old Apr 10, 2023 | 01:18 PM
edzvet's Avatar
edzvet
I suspect the battery. I pried the top off of it and checked the specific gravity with a hydrometer and got readings that were on the low side of acceptable and inconsistent. one of the cells was low on fluid and this is a new delco battery. I installed an Optima battery, indexed the windows and so far everything works as it should. Intermittent internal short? maybe
Old Apr 11, 2023 | 05:02 PM
c5arlen's Avatar
c5arlen
There you go!.. Just get a new battery.
Old Apr 11, 2023 | 05:03 PM
c5arlen's Avatar
c5arlen
Yep.
