I have pulled my motor for a some work and It is enroute so I am prepping for install. On the passenger side of the block, there is a sensor that is retained in the block by a bolt. The wires came out of the connector as I tried to connect it. What is that sensor called? Does anyone have a wire layout for the connector?
