Radar
Old May 9, 2023 | 05:12 PM
Bacon55's Avatar
Bacon55
7th Gear
Default Radar
Hi guys,
where do you put the radar in zo6 convertible in california
Old May 9, 2023 | 05:20 PM
squirrelchew's Avatar
squirrelchew
I didn't realize corvettes had radars!
Old May 9, 2023 | 05:26 PM
Grand Slam's Avatar
Grand Slam
Most people mount a radar detector under the mirror and use a special tap to access the power behind the mirror:
https://blendmount.com
Old May 9, 2023 | 05:31 PM
dvilin's Avatar
dvilin
Exactly where and how I have mine mounted in my Z06 Convertible.
Old May 9, 2023 | 05:51 PM
Factoid's Avatar
Factoid
Same in my ZR1.
Old May 9, 2023 | 06:51 PM
naylor99's Avatar
naylor99
V1 (second gen) with Blendmount and mirror tap. You can also see my 2 channel Blackvue dashcam. The rear facing cam is there as my C7 is a vert.
Old May 9, 2023 | 07:22 PM
Bacon55's Avatar
Bacon55
7th Gear
Are you in California? I believe it is illegal to put the radar anywhere that partially blocks your view? Is putting underneath the rear mirror okey?
Old May 9, 2023 | 07:53 PM
VinceC5's Avatar
VinceC5
Originally Posted by Bacon55
Hi guys,
you can put him in the passenger seat, but NEVER let him drive.
Old May 9, 2023 | 11:18 PM
naylor99's Avatar
naylor99
I am in Texas. Just passed my state inspection. Its not a problem here.
Old May 10, 2023 | 07:42 AM
Factoid's Avatar
Factoid
Yes, here is how my Texas inspection goes in San Antonio. Drive up to the local Take Five oil change place (no appointment). Tell them I’m here for inspection and given my low front splitter I don’t even drive in the bay. They have me demo lights, horn, washer fluid and pay my $7. Five minutes later I’m on my way home!
Old May 10, 2023 | 12:16 PM
naylor99's Avatar
naylor99
Ah, so your county has no emissions test requirement. Not so in Dallas.
Old May 10, 2023 | 01:04 PM
shaark92's Avatar
shaark92
thanks. I've been living with the suction cup thing, too on my entry level uniden. the mount costs as much as the detector! LOL but it is a good setup. Previously obtained that power wire hootus, too, yet installed.
Old May 10, 2023 | 01:07 PM
CPB's Avatar
CPB
I like mine high against the headliner using a permanent windshield mount. Inexpensive compared to the blendmounts. Out of my visibility and any spectators.
Old May 10, 2023 | 01:34 PM
Factoid's Avatar
Factoid
Blendmount is ridiculously priced. Here is a link to the mount and tap for a Uniden that I used for less than $50.
Radar Mount Mirror Mount Bracket + Mirror Wire Power Cord for Uniden DFR (3001109) https://a.co/d/7awko4i
Old May 10, 2023 | 02:52 PM
dcova's Avatar
dcova
Consider a remote mounted radar detector as an option.
Old May 10, 2023 | 02:56 PM
saleen556's Avatar
saleen556
Can’t argue that it’s expensive. However the quality and design are much better than anything I’ve seen. I’ve had them on several vehicles with zero issues.
Old May 10, 2023 | 03:03 PM
saleen556's Avatar
saleen556
Which one is this? I’m considering the R9 when it’s available after I see some reviews. The only issue is there is always something better coming out. It’s a lot easier to cough up $600-$800 every couple years VS several K.
To Radar
Old May 10, 2023 | 03:58 PM
CPB's Avatar
CPB
This appears to be blocking the brake cooling duct.
Old May 10, 2023 | 05:07 PM
dcova's Avatar
dcova
The original factory installed grille on my Stingray did not include ventilation in the area of the radar antenna.
Old May 10, 2023 | 05:31 PM
SD_Dave's Avatar
SD_Dave
Dr. Dave
You could use this:
https://www.sandyeggodesigns.com/pro...r-c5-c8-coupe/
