Exhaust question
You can then probably install the aftermarket exhaust without removing the diffuser, but it will be a PITA. It requires quite a bit of pushing, pulling, and wiggling to get everything to fit correctly; and you'll probably bang the mufflers & your hands against the diffuser several times in the process.
On the Borla system, the mufflers & pipes are separate. It should work.
- Remove license plate
- Remove two 10mm bolts behind plate
- Remove two 10mm bolts above the tailpipes
- Remove ten 7mm bolts from the bottom of the valance
- Release three tabs on outer edge of valance screens connecting to the fascia (these can be a little tricky the first time)
- Pull valance away from the car at the bottom to reach in and release the middle tab holding the reflectors on
- Remove two 10mm bolts from behind each reflector (now it just tabs holding it to the car at the top)
- Reach up to each top corner to release the connector tab holding the valance to the car and it will pop free to remove
I made a quick reference image highlighting everything I mentioned above that's included below along with another image that better shows the location of the bolts behind the reflectors. The circles show roughly where the tabs are that need released and the arrows are of the bolts to remove. The three outer 7mm bolts on each side are roughly in the area I pointed out, hard to show directly on that image but they're clustered together in the bottom corners, can't miss them. If I missed anything or I'm off on the number of tabs in some places, my apologies, I'm writing this up from memory at my desk.
One thing to keep in mind that sometimes isn't referenced in instructions. When removing the driver's side factory muffler on a C7 with an automatic transmission, you will have to set the parking brake and move the shifter all the way back to the M position for the paddle shift option. This will raise the shifter linkage up high enough for the over axle pipe to clear and be removed. Otherwise, the linkage sits too low and you will not have enough room to remove the pipe/muffler as it will get hung up on the linkage.
The time spent cutting and fighting everything out very well could be longer than just taking the valance off. The only points of care where things can be easily broken if you're not careful the first time are the tabs for the valance screens.
I hope this helps! Happy to answer any questions anyone may have!
-Nick
Last edited by Mid America Motorworks; Jul 28, 2023 at 11:25 AM. Reason: Additional info
-Nick
-Nick
-Nick
-Nick
