Leather Scratches / Gouges, HELP
Old Aug 18, 2023 | 10:26 PM
jake_C7's Avatar
jake_C7
Default Leather Scratches / Gouges, HELP
Any tips or tricks to get these gouges out ?
Used a reach tool to get the inside windshield in my corvette cleaned and found out that I f****d up the dash in the process. Any help would be appreciated.
in the first two photos your looking at the scratches through my windshield from the outside. This is the dash right at the edge of the windshield.
Old Aug 18, 2023 | 11:50 PM
Find a vendor that fixes interior blemishes for local dealers - those guys can do wonders when it comes to fixing mistakes.
Old Aug 19, 2023 | 04:28 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Good advice! I had a guy at the Thousand Oaks Auto Mall make 16 rock chips disappear on my C4. His guys blended the paint.
Old Aug 19, 2023 | 10:18 AM
Grand Slam's Avatar
Grand Slam
I was thinking of using one of those tools instead of my fingers but didn't know it could cause damage. Thanks for the warning.
Old Aug 19, 2023 | 03:46 PM
jake_C7's Avatar
jake_C7
Does anyone know if the top part of the dash (see screenshot - red arrow) is its own part # ? or is it all part of the instrument panel ? This diagram #5 throws me off.
The red arrow is the part I scratched up with the cleaining tool.
Also been thinking, just cover that part in anti glare suede like they do in the racing world. this is the stuff
Old Aug 19, 2023 | 04:27 PM
jake_C7's Avatar
jake_C7
Tried to get some better pics of the damage:
Old Aug 21, 2023 | 04:56 PM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
Check out a vinyl pro shop. They will be able to repair it and you will not be able to see it at all. I have a Lund Tyee boat and the seats had some a couple tears and they fixed them and you could not tell they were torn at all.
Old Aug 22, 2023 | 05:52 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
From what I have seen, the dash has to come out for the repair.
I took my passenger door panel off to adjust the window. It was slightly low on the front for some reason.
When all the clips finally let go, the panel slipped out of my hand and scraped the concrete on the right bottom edge.
It was not very noticeable but I knew it was there.
I called a local mobile vinyl repair company and for $100 it was back as new.
Now to my point. The tech that came out had to have some room to work to apply the coatings and mix the color.
They use a heat gun between applications. First thing he asked when i called if the tear was close to glass.
They will not fix it close to glass. IMHO ,your dash has to come out for any repairs.
Good luck. Call a vinyl and leather repair guys. They do wonders. But be prepared for them to walk away because the damage is near the windshield.
Old Aug 22, 2023 | 07:08 AM
449er's Avatar
449er
CF Community Team
It is tough to get your fingers in there to try to clean the glass for sure
Old Aug 22, 2023 | 10:06 AM
Flattman's Avatar
Flattman
In that case I would think windshield removal would be a less expensive and intrusive option? I have an use one of those cleaner tools the OP used - I'll have to make sure to be careful with it.
To Leather Scratches / Gouges, HELP
