Interior motion sensor question
Old Aug 19, 2023 | 06:45 PM
MSGT-R's Avatar
MSGT-R
Default Interior motion sensor question
Just purchased a 2017 GS 2lt.
Yes, I have a button to turn it off..
I turn it off, get out, lock the car.
This darn sensor re-arms itself, and is really pissing off the neighbors. No one has touched it, no one has driven by, everything motionless.
Is it re-arming itself when I lock it?
Is the sensitivity adjustable?
Are the aircraft in the departure pattern from San Diego somehow interfering with it (navigation aids)?
I had to pull the horn fuse to keep the natives happy (and the starter fuse so no one can drive off with it).
I read the other thread from 2020, and learned nothing new.
I don't mean to be a problem.
Old Aug 19, 2023 | 07:05 PM
Goat 2 Vette's Avatar
Goat 2 Vette
What are you talking about? What sensor? You don't need to manually lock the car, it locks itself. You can turn it off if you want.
Old Aug 19, 2023 | 07:21 PM
miami08VETTE's Avatar
miami08VETTE
Not sure what sensor you're referencing. The motion sensor takes quite a bit to trigger. Other than that, only other alarm occurs when a door is opened without a FOB being close by. Interesting...
Old Aug 19, 2023 | 07:37 PM
aklim's Avatar
aklim
The button next to the trunk release? AFAIK, that is for the INTERIOR sensor. IOW, say you have the top off and park the car. If someone tries to get in, it should go off. If you really want to test it, have someone test it by you sitting still in the car and they walk away and lock it. Now if you move, the alarm should go off. If you have disarmed it via the button, it should not go off. I would definitely replace that fuse to get it all working so you can check it. Now if it is locked and armed and you rock the car, it might go off.
I have mine set on autolock. When I am far away enough, the car locks. If the wife is in it and moves, it will trigger the alarm. If I don't want that to happen, I push that button and walk off. It locks the door but she can do what she wants in the car and nothing happens.
If you have it functioning, it might be your airplane departures are causing some sort of vibration which triggers that alarm
File Type: pdf
Old Aug 19, 2023 | 08:05 PM
owc6's Avatar
owc6
The intrusion/inclination alarm can be turned off by pressing the button on the lower dash.
This needs to be done every time you exit the vehicle.
If you take the top off or lower it, the alarm is disabled, and will not set the alarm off, unless you do the wall anchor work around on the coupe.
There is no sensitivity adjustment.
Ps autolock is a function of time, not distance.
Old Aug 19, 2023 | 09:22 PM
MSGT-R's Avatar
MSGT-R
Great responses, thanks all!
I wasn't certain if this car "auto locks" or required input from the remote.
The digital dash readout:
"Motion Sensor On"
"Motion Sensor Off"
Button on the left lower dash turns it on/off.
I'm 5'1".. my knees don't reach the dash (accidental activation).
Thanks for the PDF.
I select off, to keep the interior sensor from causing trouble.
While blowing dirt off the car (with the windows open), just an errant puff of air from the air hose caused the alarm to go off.
My husband put a piece of paper on my dashboard.. big mistake. The alarm went off.
We learned that lesson pretty quick. I'd say that was pretty damn sensitive when air from a blow gun sets it off.
Now parked at the curb with the windows up, top on, nothing dangling from the rear view mirror, and it wakes the dead. Maybe the airlines are a factor (?)
Old Aug 19, 2023 | 10:05 PM
aklim's Avatar
aklim
Good to know. I just tested it out. You are right. Time. I always thought it was distance.
Old Aug 20, 2023 | 11:26 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
I was at a Judging Meet in SoCal and it was 107F, so, I used the FOB to open the windows. They gave me my Judging Certificate in a Manila Envelope. Without thinking, I threw it into the car. I immediately knew my intrusion sensor wotked!
Old Aug 20, 2023 | 11:51 AM
Ron one's Avatar
Ron one
I also have a ‘17 2LT. I found the intruder alarm so annoying that I put black duct tape over the sensors on each side to the interior mirror.
Semper Fi
Ron
Old Aug 20, 2023 | 01:04 PM
aklim's Avatar
aklim
Semper Fi
Ron
Not sure I follow. How did your intruder alarm go off? Unless something moves in the car after it arms, it shouldn't. Mine works that way. After it locks, the alarm seems to be armed. It detects movement, it sounds the alarm. OTOH, it has sat quietly in my garage. It sits with the windows up and the roof on.
Old Aug 20, 2023 | 01:21 PM
Wickdc7's Avatar
Wickdc7
Mine goes during thunder storms I recently found out. Turned it off under the dash. Happened again. Didn't know it re-arms itself the next day? 🤔
Old Aug 20, 2023 | 01:30 PM
aklim's Avatar
aklim
Interior motion sensor or what?
The inclination sensor can set off
the alarm if it senses movement of
the vehicle, such as a change in
vehicle orientation.
The intrusion sensor monitors the
vehicle interior, and can activate the
alarm if it senses unauthorized entry
into the vehicle’s interior. Do not
allow passengers or pets to remain
in the vehicle when the intrusion
sensor is activated.
Before arming the theft-deterrent
system and activating the intrusion
sensor
Are you sure what is activating? Is it the inclination sensor or the intrusion sensor?
Old Aug 20, 2023 | 02:49 PM
Bill Dearborn's Avatar
Bill Dearborn
"Motion Sensor On"
"Motion Sensor Off"
Thanks for the PDF.
I deactivate mine after I get out of the car but before I close the door. When deactivated there is a small light in the center of the button that stays lit. I have found the alarm doesn't always deactivate when the button is pushed (not sure why), however, you need to make sure the light is on before closing the door or the motion sensor is still active. It may take a couple of pushes on the button to make sure the alarm is off. If you open and close the doors the alarm will reactivate unless you push the button again.
I trailer my car to track events and have found the alarm will sometimes sound off as soon as the trailer starts to move or sometimes it waits until I have driven several miles and then sounds off.
I do have OnStar active on my car and as soon as the alarm is triggered I receive an email stating somebody is breaking into my car.
Bill
Old Aug 20, 2023 | 02:54 PM
aklim's Avatar
aklim
Bill
Can I ask why you deactivate it when you get out? Just curious since I have never done that unless the wife decides she wants to wait in the car and we don't need to alert the entire parking lot that she is trying to steal her car from the passenger seat.
Isn't that a function of the motion sensor that feels your car is being moved when it shouldn't be?
Maybe you need to stop stealing your own car?
Old Aug 20, 2023 | 03:03 PM
Wickdc7's Avatar
Wickdc7
I'm not sure which one. I just hit the door unlock on the FOB to silence it, (from inside my apartment ). Happened twice one night during LOUD lighting and thunder, about 10 minutes apart. Then happened again couple days later, but that might have been from the sun shade, since it wasn't raining. Is there a way to look in the system to determine what alarm triggered?
Old Aug 20, 2023 | 03:08 PM
DALE#3's Avatar
DALE#3
Old Aug 20, 2023 | 03:11 PM
aklim's Avatar
aklim
Originally Posted by DALE#3
Shut your mouth. Someone did call the cops on us.
To Interior motion sensor question
Old Aug 20, 2023 | 04:10 PM
Catfish4818's Avatar
Catfish4818
The fob can open the windows? How do you (or better yet, I) do that???
Old Aug 20, 2023 | 04:40 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
You can deactivate the passive locking and alarm by shutting down, open the door, and then holding the unlock button for about 5 seconds; you'll hear 5 chimes.
That allows wife to stay in car and exit with the normal handle if desired. But the car won't be locked, so someone might steal her. If that's a factor, use the alarm disarm button on the dash instead.
Old Aug 22, 2023 | 10:05 AM
MSGT-R's Avatar
MSGT-R
Away from San Diego Airport, and on my last stop in Norco CA.
Last night was quiet, with no self-activations.
I'm chalking it up to low altitude aircraft interference in the departure pattern.
