Ok I am just a newb with a C7 but here goes—Is there a way to just the length of time the lights stay on after the ignition is off? I assume this is tied to the interior lights also. Thanks in advance!
Hopefully this is what you are looking for (from the Owner's Manual under Lighting).
Exit Lighting
Some exterior lamps come on at
night, or in areas with limited
lighting, when the driver door is
opened after the ignition is turned
off. The dome lamp comes on after
the ignition is changed to the OFF
position. The exterior lamps and
dome lamp remain on after the door
is closed for a set amount of time,
then automatically turn off.
The exterior lamps turn off
immediately by turning the exterior
lamp control off.
This feature can be changed. See
Vehicle Personalization
