Dim dash lights
Old Oct 16, 2023 | 03:26 PM
Mineolajoe's Avatar
Mineolajoe
Default Dim dash lights
My brother’s 2014 Stingray has instrument panel lights that go very dim once the light sensor kicks in as it gets dark. I can dim them even more or black them out with the adjustment ****. At it’s brightest, the instrument panel lights are barely legible. The HUD is as bright as ever. Turning the **** all the way clockwise turns on the interior lights as it should. Bad controller behind the adjustment ****? Is this a quirk of the ‘14 model? My ‘16 doesn’t have this problem.
Old Oct 16, 2023 | 04:03 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
My 16 is like this. Very hard to see when dimmed at sunset.
Old Oct 16, 2023 | 08:19 PM
Grand Slam's Avatar
Grand Slam
Sunrise and sunset confuses the dash lights. Just keep driving until the proper lighting kicks in.
Old Oct 16, 2023 | 08:28 PM
Mineolajoe's Avatar
Mineolajoe
In the past two years the proper lighting has never kicked in. Actually, the lights seem to be getting dimmer over time.
Old Oct 16, 2023 | 08:31 PM
I do not recall having any dash brightness issues with my 2014. I will have to check it out next time I drive the car.
Old Oct 16, 2023 | 08:35 PM
mdolandese's Avatar
mdolandese
On my 19 Z when the the auto lights go on my dash gets very dim. It’s much harder to even see the screen on the infotainment screen
Old Oct 16, 2023 | 08:50 PM
Mineolajoe's Avatar
Mineolajoe
On this car the infotainment screen is bright enough but not the instruments.
Old Oct 20, 2023 | 12:36 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Mine is the same way.
The instrument cluster sensor is independent of the headlights.
I have had mine get brighter and darker regardless whether you have the headlights on auto or manual.
Dawn and dusk are the worst times to drive with this setup.
Once completely dark outside, although dim on its highest setting, the cluster is more visible. Then at dawn, when it gets brighter outside, the full lighting kicks in and it's real bright then.
No settings in the infotainment for that. I wonder if the dealer can make adjustments to its sensitivity or brightness level.
I would love for my cluster to stay full bright when the dimmer wheel is full on.
To Dim dash lights
