Side marker Tint overlay removal
Old Nov 11, 2023 | 04:11 PM
ren80's Avatar
ren80
Default Side marker Tint overlay removal
My 2014 has smoked overlay tape on the side markers and rear reflectors. What's the best procedure to get rid of these? I assume I have to heat them?
Old Nov 11, 2023 | 06:41 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Hair dryer or a careful use of a heat gun. I would suggest removing them and work on them off the car. They are not that hard to remove.
You also want to make sure that's a tape overlay because you can buy these items in smoke lenses as well.
Old Nov 11, 2023 | 10:50 PM
Old Nov 12, 2023 | 12:08 AM
Pineapple's Avatar
Pineapple
Hairdryer/Heatgun as mentioned however be careful not to put it to close. Safest is a cheap $25 handheld clothing steamer from Walmart/Target.
Old Nov 12, 2023 | 09:00 AM
BAT's Avatar
BAT
2026 Corvette of the Year Finalist - Modified
2025 C7 of the Year Winner - Modified
2024 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
2021 C7 of the Year FinalistAX - Modified
Might be easier to swap with someone that has a stock set and looking for a tinted set?
Old Nov 13, 2023 | 07:18 PM
Avanti's Avatar
Avanti
Hair-dryer... not a heat-gun unless you are experienced with the latter. I've seen too many screw-up with them. Take your time and after remova; use GOO-GONE or similar to clean-up the adhesive-like residue, if there is any. Be patient. All the best.
Old Nov 13, 2023 | 07:32 PM
Tommy79's Avatar
Tommy79
Nice timing on post.. I'm probably getting ready to sell my car and would remove my high dollar side markers and re-install the factory ones. Mine have the gray cover. I was unaware that you could remove the tint.
Thanks!
Old Nov 13, 2023 | 08:49 PM
ren80's Avatar
ren80
Thanks for responses.... its definitely tape. I can lift a corner to peel it off. Seems like it is pretty aggressive tape though. Not really a big deal. I will give it a try... if its too difficult I will just leave it.
Old Nov 14, 2023 | 08:18 AM
Bills17n72's Avatar
Bills17n72
To Side marker Tint overlay removal
