starting question
Old Dec 26, 2023 | 03:29 PM
Stop Flop's Avatar
Stop Flop
Supporting Vendor
Default starting question
2014 Z51 LT3 STICK. I was trying to start my vett but when i push the button nothing would happen. Just got a tic tic noise and a blank screen. But when i shut the driver side door it started just fine. So my question is does the door have to be shut for the push button to engage?
dave
Old Dec 26, 2023 | 03:54 PM
dlsmith82's Avatar
dlsmith82
yes
Old Dec 26, 2023 | 03:56 PM
Stop Flop's Avatar
Stop Flop
Supporting Vendor
thanks, for the past 6 months its been doing this and i had not idea the door needs to be closed. Even brought it into the shop 3 times claiming sometings wrong! DUH
Old Dec 28, 2023 | 10:37 AM
DoubleG's Avatar
DoubleG
What? No way. I can't believe they make you shut the door now. I've never noticed if I have to, but I will check now. It makes no sense. I have the same car, but auto. The manual also mentions nothing of this for stick or auto.
Old Dec 28, 2023 | 10:42 AM
dlsmith82's Avatar
dlsmith82
The hood has to be closed too!
Old Dec 28, 2023 | 11:53 AM
DoubleG's Avatar
DoubleG
Now I know you're joking
Old Dec 28, 2023 | 12:39 PM
Stop Flop's Avatar
Stop Flop
Supporting Vendor
So the door doenot need to be shut? i have a problem and just asking for help.
Old Dec 28, 2023 | 02:21 PM
DoubleG's Avatar
DoubleG
I just started mine with the door open and the hood up just to assure myself I wasn't crazy thanks to dlsmith82.
Does it do the same if the passenger door is open?
First, thing most people will ask you is if the battery is old. If the battery isn't near perfect, weird electrical issues pop up.
Old Dec 28, 2023 | 05:18 PM
dlsmith82's Avatar
dlsmith82
I swear my 2016 would not start with the hood up! see last paragraph of page from owners manual! Obviously the 2016 is different than the 2014!
Old Dec 28, 2023 | 05:44 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I would start looking at the battery clamps. They may be loose and when you shut the door, they jar.
I have no other answers.
Open doors have no impact on whether the car should start or not. Mine starts regardless of the door position.
Old Dec 28, 2023 | 06:30 PM
westsdad's Avatar
westsdad
This (OM section for remote start) is only for a remote start that the hood can't be open. Due to safety reasons.
Doesn't matter for the OP as there is no remote start for an M7. Once again, due to safety reasons / M7 not left in neutral.
Old Dec 28, 2023 | 11:06 PM
Old Dec 29, 2023 | 08:20 AM
Tinkertech's Avatar
Tinkertech
Don't forget tire pressure and blinker fluid!
To starting question
