2014 cameras
Old Jan 29, 2024 | 02:33 PM
cberistain's Avatar
cberistain
Default 2014 cameras
what is the best way to get a front camera and also the all around looking from the top down camera system?
I have a DYI front camera, but it requires using the iphone to access the camera and takes too much time..
thanks
Old Jan 29, 2024 | 04:58 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
My camera is front looking and works on the NAV screen as does the stock system. It can be turned on manually and stay on OR it will come om when you put it in drive after backing up and the it will go off around 9 MPH.
I hooked mine up to Navtool. https://www.corvetteforum.com/forums...tallation.html
Elmer
Old Jan 29, 2024 | 06:52 PM
cberistain's Avatar
cberistain
is Navtool still recommended?
Elmer
Old Jan 29, 2024 | 07:09 PM
eboggs_jkvl
Moderator emeritus
Recommended by who? I have it. It works flawlessly. So, I would say at least I do. If you have some other source that doesn't use a phone or extra screen or need something in the cubby to function or function as the stock camera on the later years did, then go for it. I know some other vendors don't like it but it is their competition and nooooo vendor would bad mouth a product that they don't sell?
I can only tell you what I have and it worked since 2016. I've helped 2 other guys install the product. Theirs is still working as advertised.
Elmer
Old Jan 29, 2024 | 07:10 PM
stevettec7's Avatar
stevettec7
I have Navtool in my ‘15. It works great. One day I may actually use more than just the center view. I believe it has 6 sources it can display??
Old Jan 29, 2024 | 09:06 PM
cberistain's Avatar
cberistain
As I remember, when the navtool first became available for the 2014 corvette, there was a delivery problem... many missed promises .. but I didn't follow through to know if these issues were solved... I don't think there was ever a reliability problem,..
Old Jan 29, 2024 | 11:25 PM
Navtool can be an option. Wouldn’t mind having it in my car.
Old Jan 30, 2024 | 06:49 AM
Tinkertech's Avatar
Tinkertech
Still have my Navtool in my closet, just too lazy to install it.
To 2014 cameras
