Installing Side Skirts
Old Feb 14, 2024 | 12:24 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default Installing Side Skirts
I ordered the EOS side skirts for my 2015 from EOS and they are due here next Tuesday. So, before I go any further, I want to say that they are extremely fast on shipping. I ordered them yesterday and I received the tracking number within an hour of placing the order.
So, onto the installation issue. I have watched a few videos, and they all just simply go about screwing the skirts on with the screws provided and that is where I have a little concern. It is fine on the passenger's side, but if you have the A8 there are transmission colling lines that run inside an area in the rocker panel. I found on the forum here where GM instruction for the installation of the Z06 side skirts that not to drill deeper then 12mm or a little less a half inch so as not to take the chance of hitting a transmission line.
Anyone have any further info on this, and are the screws supplied short enough.
Old Feb 14, 2024 | 12:53 PM
astepup's Avatar
astepup
First off in my opinion don't use any screws to secure the skirts, but use split rivets. I know ACS provided two different lengths but I can't recall the sizes. I mounted full length skirts on both of my C7's with no issues. I marked a spot on the drill bit for the driver side rear drill points, then proceeded SLOWLY with little pressure and it went well. Take the time to do it right and you'll be happy you did 👍
Old Feb 14, 2024 | 01:09 PM
chambers115's Avatar
chambers115
I am contemplating side skirts on my 2017 with M7, is there anything I should be concerned about when drilling on either side?
Old Feb 14, 2024 | 01:34 PM
shekmark427's Avatar
shekmark427
I watched several different You Tube videos to get ideas. Screw vs rivet seems to be a wash , but ASC says rivets and , even though I bought cheap, I trust their opinion. Nobody seemed overly concerned about hitting trans lines. Maybe if you are very heavy handed? I may do screws provided and tap, and if I love them, I will consider replacing the screws with rivets. That's todays plan. Tomorrow may change. Too cold to do now anyway. I bought $160 Ebay side skirts but in the spring I may just buy the Carbon Flash ASC.
Old Feb 14, 2024 | 06:34 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Detail shop used the screws provided with the skirts along with some 1" double sided tape.
There were no issues. Mine is also a Z51 A8.
Old Feb 14, 2024 | 07:36 PM
guido7834's Avatar
guido7834
This is what I did with mine. There are factory screws on the underside of the body panels. Two or three in front and back I believe. Clean the bottom panel well, wipe with alcohol and apply 3m double sided tape the whole length. I also used some adhesion promoter as well. Over 6 years and still good as new.
Old Feb 14, 2024 | 08:51 PM
I installed side skirts on my 2014 using a couple of screws and the rest in rivets. Solid as a rock. I have the A6 and was just careful on the driver’s side -I pulled the rear fender liner on the from wheel area back and did not see anything that would be a problem with installing the skirts.
Old Feb 15, 2024 | 12:21 PM
JasonR2021's Avatar
JasonR2021
I installed mine with no knowledge of trans cooler lines on the driver's side. My instructions only said don't drill deeper than 12mm. I set a collar roughly 12mm on the bit and drilled. Toward the middle of the door there is metal right behind the fiberglass. I drilled through it but wish I hadn't. It was about a week later I learned about the trans lines and I panicked. I lost a lot of sleep over it. I tried to run an inspection camera down the rocker to make sure I hadn't hit them but it only went down a short way and was blocked. I never had any fluid on the bit when I pulled it out and I've driven the car about two hours since with no issues so hopefully I'm fine. Like you I watched 3-4 videos on installation and not one of them mentioned the danger of the trans line on the driver side. I bought a rivet gun and some rivets and I'm planning to replace all the screws with rivets. Best of luck on your install.
Old Feb 16, 2024 | 07:59 PM
96GS#007's Avatar
96GS#007
Remember this if you use screws. The fiberglass you drill through is about 1/8" thick. Now look at the screws. You have virtually no thread engagement. This is why GM used split-rivets.
Old Feb 19, 2024 | 01:41 PM
CraigStu's Avatar
CraigStu
I did the drill collar thing too. Just no reason not to. You can also use a section of any hose that will slip over the drill bit like vacuum hose or w/s washer hose. I used other screws than provided because I saw the same thing 96GS007 mentions. Seemed the threads stopped 1/16" inch away from the underside of the head.
Old Feb 19, 2024 | 05:48 PM
H Watkins's Avatar
H Watkins
St. Jude Donor '15-'16, '21,'24
I used these:
25 Bumper Fascia & General...
Amazon Amazon
To Installing Side Skirts
