eLSD calibration/bleed at beginning of every drive
I found this thread that states the the eLSD will execute a bleed cycle every 3rd start on the 2016s.
https://www.corvetteforum.com/forums...key-cycle.html
My 2014 does this at every start, no codes, car drives normally, I was just wondering if this is normal behavior?
Thanks in advance for any replies.
How often are you starting it? If you start it, let it doing it’s thing, shut it off and start it up again right away, does it do it then as well?
I mostly hear it do the purge when it’s cold outside. In the winter, I felt like it did it all the time. Now that the weather is warmer, I don’t hear it as much.
I should have been more clear, it it does with every drive cycle, I need to actually get a bit of speed up say 10 miles an hour to trigger it.
If I just pull it out the garage and then back in it doesn't run the bleed cycle.
