I've had a cooling-related problem for a while. My car will be fine for 100 miles or so of normal highway driving, then suddenly, for no apparent reason, the temperature gauge will suddenly go from normal 220° to past 260° in seconds with warning dinging and dashboard warning lights. I'll pull over and turn the engine off for a couple of minutes or shift to a higher gear for lower RPMs and the temperature gauge will just as suddenly go back to normal 220°. That can't be sudden overheating. It's got to be an electrical problem. Any thoughts guys?
This is not the Corvette ownership experience we strive for. Our team would like the opportunity to learn more about the overheating on your C7 and investigate ways we can potentially assist. When you get the chance, please send us an email to socialmedia@gm.com. Be sure to include your Username and Forum name in the subject line, then provide additional details about your experience in the body of the email. We look forward to your contact.
Sounds a lot like what I had in my last C7.
It turned out to be air in the system. At least that's what the shop told me.
I did not have any more problems after they fixed it.
GM guys are pretty good. I would just ad that Corvettes are unque in many ways, but one is the owners. Many Corvettes are garage queens, never driven in cold weather......
As such the interior heaters are rarely used and even when they are it is long times between uses.
My thinking is that when the heater mode operates it allows water to go through the heater core which flushes out the water that has been in the core forever. this bad water may have crap in it and clog sensors, thermostates, ect. and so to avoid this I suggest all Corvettes be run with interior heater mode several times a year. Keep the water moving, flushing out the system. my two cents
Thermostat
Fan
Air in the system (although this is unlikely if it hasn't been recently flushed)
C7 Corvette has constant flow through the heater core. It uses a diverter door to block the heat when not needed. I don't recall Corvettes having a shut-off valve since the early days of the C4 or maybe even late days of the C3.
What year is your vette? Please add some info to your profile.
There was a problem on some 2014s with the fan controller. It is built in to the fan assembly, so the entire fan assembly needs to be replaced. Many replaced with Z06 units. (I had no problem with my 2014).
What does add some info to your profile mean? Go up to the top right of the screen where your sign in name is located, click the arrow to expand, select MY PROFILE and do some editing. This is the public profile that others can see. You can list as much detail as you want. It would be really helpful when you ask questions if others can look and see what year, transmission, major options, etc. your car has.
You just click on someone's name to see their public profile.
My Vette is a 2014 with Z51 and a 7M transmissio and 121,000 miles. Thank you all for your suggestions, but they don't really address the the very temporary and intermittent nature of my problem. I can sometimes drive 200 highway miles with no problem. Or I can drive 10 miles and the temperature gauge can quickly (20 seconds or so) go from 220° to past 260°. If I ease up and put it in a higher gear, it can just as quickly go back to 220° and stay there.
<snip>
I don't have an issue with temp spikes and never considered the fluid in the heater core before this thread. Living in SW Florida heat is seldomly/if ever required. But I s'pose it be a good idea to flush it and refill....
Since you seem to indicate that your C7 is a 2014 model I'd be suspicious of the fan and its controller.
But since you have indicated that the temp swings wildly and fast I'd lean towards an electrical issues.
Also the 14 model analog gauge really isn't a gauge. Its an indicator that reads low, medium, high. Only the DIC will give you the correct temp.
Connect a scanner, if you have one, and monitor all the PID's that are related to this issue. Easiest and best way to track it down.
If you don't have a scanner first check all your grounds in the engine bay and all battery connections. If this doesn't fix the problem and you just want to shoot the parts cannon at it, start with the temp sensor then the thermostat then the fan and controller.
Good luck and let us know what you find.
If you’re getting wild swings with coolant temperatures, it’s not very likely that you’re experiencing an actual overheating condition. It’s more likely a bad coolant temperature sensor. Try replacing the sensor. It’s an easy repair and easy to access, located near the thermostat housing on the top front of the engine. The part is fairly cheap (OEM Delphi found at Rock Auto $24).
Here is another vote for the thermostat and/or coolant temperature sensor.
Both are very easy to replace, and inexpensive. With your mileage, I would suggest changing both out. Even if it doesn't fix the problem it will still be a good idea.
Good luck!!
I don't believe a bad tstat could allow a 40 degree temp rise or fall in 20 seconds, so I'd bet on the temp sensor. However, given the age of your car, I'd also ask when the coolant was changed. There are procedures around that describe how to change the coolant and get the correct ratio of water/coolant, so given what I've been through with my 14, I'd change the tstat, sensor, and coolant at the same time. Note that later year stingrays use a cooler thermostat (190 I think) than the stock temp for the 14 which is a 207. So I'd opt for the later temp rating as 207 just seems too high to me.
IMHO, if you are at 220* just cruising down the highway, you already have some sort of problem before it goes to 260*. If the temp reading is legit, then you probably have air in the system or a thermostat problem. My guess is either a bad temp sensor or a bad thermostat, although taking a shot at burping the system would be a good idea as well.
