The. Ultimate. Acceleration
Old Jun 13, 2024 | 03:46 PM
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
Default The. Ultimate. Acceleration
SOLER PERFORMANCE | GENERAL MOTORS
JUNE DISCOUNT CODE: SALE5PNEW option: A brand new reworked part (0 miles / BNIB).
CORE EXCHANGE option: A refurbished and reworked part shipped right after your order. The $X deposit is refunded when we receive your unmodified core unit within a month of order delivery.
REFURBISHED option: A refurbished and reworked part shipped right after your order. No deposit or core return is required.
REWORK YOUR OWN option: Ship your unmodified unit to us right after placing your order, we’ll rework it in 1-2 business days and send it right back to you. Contact us prior to order if reworking an already modified or ported unit.
FEATURES: • Optimized Active Contours with sonic flow nozzles • Porting Taper and Upstream Bore with Velocity Stack • Greater Discharge Coefficient of Plate/Blade interface • 16 Ra Microinch, Diamond Polished Surface Finish • Shaftless high-pressure side of the blade for Larger WOT Flow Area (91 mm Effective Bore) • Self-Cleaning Throat/Flow Gap • Dome and Thread-locked Screws • Dimpled shaft trailing edge
BENEFITS: • Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience • Linearization and smoothing of the curve for a more predictable response and crisper shifts • Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble) • Does not require tuning. Warranty safe. • More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
1 YEAR WARRANTY*.THROTTLE CONTROLLER:
The perfect match for our Throttle Bodies. Easy installation. Premium features.
SE0525-TC DLX BLUETOOTH® THROTTLE CONTROLLER: CORVETTE 7/8, CAMARO 6, CADILLAC CTS 3 & MORE
FEATURES: Dual control, directly on the display or remotely from your smart device. Ten Modes, with a total of 64 possible settings (see chart). Sturdy aluminum construction, buttons, and heavy-duty harness. Self-adjusting OLED display intensity for optimum visibility. Real-time throttle position gauge. Fail-safe vehicle-specific design. Does not require the display to operate, for those who prefer a fully concealed device.
BENEFITS: Controls pedal sensitivity, allowing the driver to adjust an otherwise widely considered non-linear (slow/spongy) pedal response/map. Increases the sensation of acceleration/power, very important for driving pleasure in finely tuned sports cars. Complements performance Throttle Bodies in achieving total throttle control as a system. Plug-and-play modification. Warranty safe modification. Easy installation (15 min, no tools or special skills required).
Old Jun 19, 2024 | 05:08 PM
Mike@SolerEngr
Supporting Vendor
Website: SOLER PERFORMANCE | GENERAL MOTORS
Email:tiffany@solerengineering.com
Call/text: (251) 468 - 9786
Follow us on Instagram: SOLER | PERFORMANCE
Old Jun 24, 2024 | 10:03 AM
Mike@SolerEngr
Supporting Vendor
Old Jun 27, 2024 | 12:42 PM
MuscleCarDave's Avatar
MuscleCarDave
Of those who have installed these, can you tell me a bit about your install experience? I'd like to hear direct from the users and not just the company spokesperson.
It seems the install is easy, but my questions are more around the usability...for example if you don't want the device to be seen and therefore hide it under the dash...is it the type of thing where you set it once and then don't really need to see the display? I don't think I'd want the display visible, so "set it and forget it" would be my preference. The web says you can display it on your smart device, so I assume you have to download an app, create an account, etc.? Any other comments? What is displayed on the device (or in the app) that I would want to see while driving?
I just noticed it looks like the display is not "connected" by a cable, thus the bluetooth comment...so if that's the case and I don't want the display to be mounted, can I just put it in a glovebox/console or something?
Last edited by MuscleCarDave; Jun 27, 2024 at 12:49 PM. Reason: Added last sentence
Old Jun 27, 2024 | 03:25 PM
Catfish4818's Avatar
Catfish4818
It seems the install is easy,(yes; very easy) but my questions are more around the usability...for example if you don't want the device to be seen and therefore hide it under the dash...is it the type of thing where you set it once and then don't really need to see the display? I don't think I'd want the display visible, so "set it and forget it" would be my preference. Yes, once I installed the throttle controller at the accelerator pedal, I routed the cable that leads to the display unit under the console side trim, and I keep the display unit inside the console. See attached pic.
The web says you can display it on your smart device, so I assume you have to download an app, create an account, etc.? Yes; download bluetooth app. No account needed. Any other comments? The throttle controller can be controlled either by the phone app, or by the buttons on the display unit What is displayed on the device (or in the app) that I would want to see while driving? See attached pic of iphone screenshot.
I just noticed it looks like the display is not "connected" by a cable, (sort of. The iphone app is not connected by a cable; the display unit is connected by a cable) thus the bluetooth comment...so if that's the case and I don't want the display to be mounted, can I just put it in a glovebox/console or something? Yes, and maybe to clarify - the iphone app is connected wirelessly; the display unit is connected via the wire that I hid alongside the console, and then kept in the console.
edit - I forgot to add that there's another component to the TC assembly that's spliced in to the accelerator wiring harness down by the pedal that I (and probably most folks) keep hidden by tucking it under carpeting down by the pedal. That's the source of the wire that leads to the display unit.
Old Jun 27, 2024 | 04:06 PM
Catfish4818
Also, you may have seen this on Soler's website, but if not - -
https://static1.squarespace.com/stat...Rev+NEW+V0.pdf
Old Jun 27, 2024 | 04:48 PM
MuscleCarDave
Thank you so much Catfish…exactly the info I wanted. Did yours throw any codes you had to deal with?
Old Jun 27, 2024 | 05:05 PM
Catfish4818
Nope. Never any issues. It really perks up the acceleration.
Old May 2, 2026 | 05:39 PM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
Hypothetically, if someone were to remove the display module from the console, would the car still be able to be started & driven without it or would you be stuck?
Old May 2, 2026 | 08:18 PM
UpNorthC7's Avatar
UpNorthC7
If you have the newer, Bluetooth version you don’t need the display module, you can control it from your phone. From day one , I removed the display module, tucked the wire behind the carpeting and went on my merry way. Like many others have done. I have to believe if by some strange chance you don’t own a smartphone, you could set the controller to the desired setting, unplug the display and you would be fine. It won’t brick your car.
To The. Ultimate. Acceleration
