I am getting ready to drain and fill the diff. It's my new to me 2014 Stingray, 23k miles and I'm the second owner. The aluminum cross member behind the mufflers has this plastic yet flexible piece bolted into the cross member. Is it a cradle for the floor jack ?
I think it is an air deflector which is found on convertibles. Uh, is yours a convertible?
Look at the stickies at the top of this forum to find the jacking points.
Yes, it is a convertible! Hmmm, it's in the way of my floor jack. I suppose I can remove it and place a 2x3 along the cross member to distribute the weight, then reinstall it.
Changed the rear and transmission fluids in April
2014 Z51, M7 vert does not have the plastic piece and there are no holes in the support.
"Deflector for additional cooling for automatic transmission convertible models (that don't have fender intakes)? Just guessing as my Z51 M7 doesn't have it.
And you right... its on the factory recommending jack location which seems odd."
