Blinking side marker lights??
Old Jul 9, 2024 | 12:26 PM
McGillicutti1's Avatar
McGillicutti1
2nd Gear
Default Blinking side marker lights??
I have a 2019 C7 Stnigray in Arctic White and I’m looking to inquire about blinking side marker lights for this car, does anyone make these? It would definitely help with safety since this car only has blinkers in the front and rear. Any information would be of use. Thanks in advance…
Old Jul 9, 2024 | 01:12 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
I have never seen blinking side markers for a C7. You would probably have to connect the existing side markers into the blinkers. Don't know if that would work either.
Old Jul 9, 2024 | 03:33 PM
Flame Red's Avatar
Flame Red
I have done this modification. This is call European style side markers for the the C7.
It is a bit involved, as what I did is I ran a new wiring harness to each side marker light. You can get the connector from Mouser. The harnesses go to the BCM under the pass side floor board where you need to install a couple relays, one for the left side and another for the right side. I wired them so that they are always on like DRL.
Here is the link on how to wire this up: https://www.corvetteforum.com/forums...post1604676216
Old Jul 9, 2024 | 11:21 PM
Have not seen what you are wanting, but I do not see why you could not make it work. Good luck and hope you’ll post up your solution if you go through with this.
To Blinking side marker lights??
