Stolen
Nothing guarantees protection from thieves but, IMO, this is a useful tool in the theft prevention tool box.
If your car is PDR-equipped, it can also be configured to record what happens every time it's started. Notably, it does NOT cripple the car. In short, it will provide you a recording of Ferris' joy ride, but will not prevent it.
When I first sat in the C7 until I bought it, it felt cramped compared to my C4. Visibility for the rear sucked. After a while, you get used it and adapt. Compared to my CL550 which was like a goldfish bowl, all other cars sucked.
Isn't there a fuse for the injectors (or something in the ignition system) that would prevent the firing of the ignition system? Could we just pull a fuse and replace it upon return? Seems low tech enough and who carries fuses for ripping off cars? Curious if I am on to something, or just another idea not thought through enough...
Now to figure out what fuse to pull thats fast and easy
Even a toggle wired in between a circuit to interrupt it works
My brother is a shop mgr, I will ask him
Personally I think aftermarket security systems are a huge red flag when buying a car. You have no idea who installed it, or if rhey fried something. Now you have a wiring liability. Its more common then people realize as Best Buy was notorious for cookin BCMs
Pulling these simple fuses will disable the vehicle, but I'm new to vette's and don't know where these panels are yet.
https://www.corvetteforum.com/forums...-fuse-box.html
Pulling fuses is a simple approach, and your average thief isn't an electrical technician to diagnose and pull covers off looking for fuses.
All they know is, it's not a quick grab n go, and there's a 99% chance they will not proceed further UNLESS it's an overnight grab
That takes time, and time isn't a luxury that they have in stealing cars.
Any urban area is a sketchy area unless it has gated / guarded parking.
Even having said that, driving thru areas like Chicago at night, criminal elements have
used multiple vehicles to pit a car & steal cars @ gunpoint.
They use signal catcher/repeaters
Everyone with a keyfob needs to be educated on proper home & street security to prevent them “catching” and repeating the FOBs signal back to the car
Faraday cage boxes or pockets can be bought to keep your keys in it
https://m.youtube.com/watch?v=m0QFVbNjfB0&pp
They are not always using signal catchers. If they can get into the vehicle they are using a dealer service tool to reprogram the RKE module with a new key fob which then allows them to start the vehicle like normal and drive away.
Same with your house. If someone wants to get your stuff they will. Nothing you can do other than live in a compound and go nowhere. Or have a personal army of security be everywhere all the time.
I bought a beater car and found out as soon as I got in that it was manual. Killed it twice on the way home but figured it out. Wasn't butter smooth or wasn't able to shift it without the clutch but got it worked out. If you tell me a pro car thief can't drive stick, I got to wonder if it is fantasy or just wishful thinking. As said, I do not think that a couple of drink HS juniors are going to be able to start it on a whim but a pro thief is going to be long gone by the time you notice it is gone and probably have it either chopped or in a crate heading overseas.
The thieves are always one step ahead of security systems
