Infotainment Screen Flickering
Old Aug 15, 2024 | 09:07 PM
JAsVette's Avatar
JAsVette
St. Jude Donor '14-'15-'16
Default Infotainment Screen Flickering
I just purchased my otherwise awesome '14 Z51 with 50k miles a week ago and the Infotainment Screen is flickering. Unfortunately I bought the car 1700 miles away or I would be bringing it back to have it looked at. Does anybody know what could be causing this and if it's an expensive fix. Thanks in advance?
Old Aug 15, 2024 | 09:16 PM
My 2014 did the same thing. Ended up having the infotainment screen replaced (thankfully under an extended warranty). When the tech was disassembling the console to get at the screen, the bezel around the shifter cracked so that had to be replaced too, also covered under the warranty. Total cost was $1300 or so.
Old Aug 16, 2024 | 09:02 AM
IA-SteveB's Avatar
IA-SteveB
Mine was doing that, so I replaced the cable that can become loose or get pinched over time when the screen goes up and down. It was $5 to fix it, but it took a good bit of labor to get the screen out of the car. I would try that first before you get crazy. The weird thing is that if you honk the horn, the screen might stop flickering for a bit, and that seems to be an indicator that the cable is bad going to the screen itself.
My '14 had black cables, but you will see blue cables a lot on how-to threads. The Amazon cable is a direct replacement, even though it looks slightly different. I no longer use the storage compartment behind the screen.
See this thread. https://www.corvetteforum.com/forums...cheap-fix.html
I have a blog post that has a video of disassembly that I found on youtube and a sample video of what mine was doing.
Old Aug 17, 2024 | 04:16 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
This is something that is not unheard of in 14's and 15's.
My '15 had that when I bought it. It was doing it the day I brought it home.
I took it back to CarMax and they ordered and installed a new screen at no cost to me.
I think it's about a $1k fix though when out of warranty.
To Infotainment Screen Flickering
