PDR Not Working
Old Nov 21, 2024 | 12:44 PM
dinows33's Avatar
dinows33
Default PDR Not Working
2018 2lt 30K PDR keeps telling me to plug in a SD card. I have plugged in 3 different cards and still get the same message " plug in a SD card " any ideas ? Thanks
Old Nov 21, 2024 | 01:23 PM
Z06_racer's Avatar
Z06_racer
Yes, the card can have a maximum of 64 GB and must be formatted in a special file system. Unfortunately I forgot what it was called.
Old Nov 21, 2024 | 03:58 PM
Bill Dearborn's Avatar
Bill Dearborn
Insert a FAT32 formatted SD card, Class 10 preferred, into the glove box SD card reader. Before inserting Ensure the switch on the side of the card is set to record. 32GB and smaller SD cards usually come formatted FAT 32 but larger cards may be formatted as exFAT or may be blank. Either way the card needs to be formatted to the FAT 32 format before the PDR will recognize it.
Bill
Old Nov 22, 2024 | 11:31 AM
Grand Slam's Avatar
Grand Slam
^^^. What Bill said. Plus be careful when inserting the card that you don't accidentally move the side switch away from the Record position.
Old Nov 22, 2024 | 08:12 PM
dinows33's Avatar
dinows33
OK Thanks, but I plugged in the one from my C8 after erasing all the data and that didnt work either ??
Old Nov 22, 2024 | 08:13 PM
dinows33's Avatar
dinows33
Will check the side switch
Old Nov 22, 2024 | 11:03 PM
dinows33's Avatar
dinows33
Can I assume the side switch should be up ?
Old Nov 23, 2024 | 09:10 AM
PJinHouston's Avatar
PJinHouston
Veteran: Marine Corps
I have a 1TB card and it works well.
Old Nov 23, 2024 | 09:11 AM
PJinHouston
I have a 1TB card and it works fine as long as they are formatted to Fat 32
Old Nov 23, 2024 | 10:28 AM
George_L's Avatar
George_L
Originally Posted by dinows33
OK Thanks, but I plugged in the one from my C8 after erasing all the data and that didn't work either ??
I don't have a C8 but I believe they are formatted in the ExFAT format which will not work in a C7 as previously mentioned. You can format any size SD card in FAT32 using free programs.
Old Nov 23, 2024 | 05:31 PM
Grand Slam's Avatar
Grand Slam
Searching online appears to confirm that C8's use ExFat, not Fat32.
Old Nov 23, 2024 | 08:20 PM
RonC7's Avatar
RonC7
Dinnows - has the PDR in this car ever worked? Above information is correct - SD card must be formatted Fat32. It can be any size - I have used up to 1TB. Note that 32gb will hold 11+ hours of recordings. Due to file size limits, you need to STOP and START every 90 minutes or so. If recording stops due to file size you don't get a warning. See SD lock / unlock switch positions below.
To PDR Not Working
