Cold Engine Temperature
Old Jan 16, 2025 | 03:19 PM
JFJr's Avatar
JFJr
Default Cold Engine Temperature
What engine temperature do you normally notice after driving about half an hour in cooler weather? I have the dry sump engine and noticed the last few days that the engine coolant and oil temperature show around 154 degrees F. and my check engine light just came on. Sounds like a thermostat and/or temperature sensor malfunction. Any other ideas?
Old Jan 16, 2025 | 04:49 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
IIRC, if the car detects that it isn't warming up properly then it can eventually set a Check Engine light.
On our 2017 Z51 A8, the coolant temp will get up to about 190'F after just a couple of miles, the oil temp will get to about 175'F but takes much longer, maybe 10 miles.
In our 60k miles, I've had two thermostats that were sticking more open than they should, coolant would wander around 170'F and the yellow band would intermittently re-appear on the tach. The CEL did not appear. In each case, replacing the thermostat fixed the problem. For a while...
GM seems to be getting some junky thermostats...
Old Jan 16, 2025 | 07:08 PM
kodpkd's Avatar
kodpkd
My bet is, it's the thermostat like he said. A very common issue. When you search for thermostat's you will get a lot of stupid info. Your car needs a 194* thermostat. Make sure it's the correct temp, and not a "liketodo" thermostat. I think part number,,,,
15-11113
https://www.ebay.com/itm/38763450232...0aAmb9EALw_wcB
Old Jan 16, 2025 | 09:13 PM
C5FORFUN2's Avatar
C5FORFUN2
$100 and one below it for $30. Looks like the same # ??maybe that would explain the thought about defective parts. Depending on where you buy and from whom. Knock offs, Chinese counterfeits???
Old Jan 16, 2025 | 09:20 PM
kodpkd's Avatar
kodpkd
It depends if you want the correct thermostat. The other ones you might see are just the thermostat without the housing. That is perfectly fine if your housing is ok, and the thermostat has the correct temp.
Old Jan 16, 2025 | 09:44 PM
Wayne442's Avatar
Wayne442
I recently had the same issue with my 2019 Stingray. Coolant temperature was hovering around 160 degrees. During the summer it had been in the 190 - 200 range. I installed a new 194 degree thermostat and it resolved the problem..
Old Jan 16, 2025 | 10:14 PM
aklim's Avatar
aklim
Did you scan it and see what the code is? Run down to your Autozone, Advance Auto, O'Riley's and their code reader and let us know what code/codes come up.
Is that what the code indicated? If so, which one?
Coolant temperature codes
  • P0128: Coolant temperature is below the thermostat's regulating temperature. This code can affect most vehicles and is usually caused by a faulty thermostat.
  • P0125: Coolant temperature is insufficient for closed loop fuel control. This code is important, but it doesn't necessarily mean the engine will be damaged.
  • P0116: Engine coolant temperature sensor 1 circuit range or performance
  • P0117: Engine coolant temperature sensor 1 circuit low
  • P0119: Engine coolant temperature sensor 1 circuit intermittent or erratic
Old Jan 16, 2025 | 10:16 PM
aklim's Avatar
aklim
Why would you reuse the housing? IF it was hideously expensive, I get that. IF not, I realize it isn't like the old days where it is made of metal. Plastic doesn't seem as tolerant of heat cycles so I would rather replace the whole thing than to have a crack before, during or after install. Or more precisely, to lower the chances of a crack sooner rather than later.
Old Jan 16, 2025 | 11:27 PM
fuzzy03cls's Avatar
fuzzy03cls
This is my recent experience as well. So far a few weeks after replacement & all is normal again.
Old Jan 17, 2025 | 04:53 AM
cuspid's Avatar
cuspid
Driving in 55 degree weather for 15 mins I still had a lowered redline and no codes
Old Jan 17, 2025 | 07:42 AM
aklim's Avatar
aklim
I think it is looking temperature rise within certain times as dictated by the algorithm and not just temperature alone.
Old Jan 17, 2025 | 12:31 PM
kodpkd's Avatar
kodpkd
Just pointing out the options you have when replacing the thermostat.
Old Jan 17, 2025 | 12:36 PM
aklim's Avatar
aklim
​​​​​​I just checked and the one they offer at the parts store website is the total package. I'd boil and cool it a few times to make sure it opens and closed smoothly. Ask me how I know.
Old Jan 21, 2025 | 07:27 PM
TxLefty's Avatar
TxLefty
I replaced mine with a Katech 174*. Works like a champ. Temperature in the cold is 172-174*. Full redline.
Old Jan 21, 2025 | 07:54 PM
aklim's Avatar
aklim
Has anyone every done the hot/cold water thing with thermostats? They seem so cheap that I can't believe they are that good, in general. I don't trust them so I have 2 pots of water on a stove. Cold and boiling hot. Dunk it in the hot and see it open completely and smoothly, dunk it in the cold and watch it close smoothly and completely. Repeat a couple times to make sure you don't miss anything. I did this because I was chasing a thermostat problem and the new one also had issues. Took it out AGAIN and did the water pot thing and found that it too was bad. Since then, I have done that pre install test and found one bad one right out of the box.
Note. This test must be done with the wife not around or asleep. Some people don't like the good cookware being used for this sort of thing. I learned that when I was trying to clean the skull cap of a deer and did it with the wife around. Needless to say, she had me take the thing out of the house to a taxidermist to do the job instead of stinking up the house and got herself a new pot.
Old Jan 22, 2025 | 08:11 AM
Tinkertech's Avatar
Tinkertech
Better sticking open than closed.
Old Jan 22, 2025 | 08:57 AM
kodpkd's Avatar
kodpkd
Yes you are correct,,,, wrong engine temp. Not good for the engine to not warm up correctly.
To Cold Engine Temperature
Old Jan 22, 2025 | 09:23 AM
CraigStu's Avatar
CraigStu
I am going to be adding the thicker radiator to my Stingray in the next month. I did a quick look at Tstats and wondered why so expensive. Shouldn't a Tstat be $30? Then I saw most listings include the housing. WTF ? Is that just a way to turn a $30 part into a $110 part to bump up profit? Or is there a valid reason to replace the housing?
Old Jan 22, 2025 | 11:00 AM
aklim's Avatar
aklim
Without subscription to the conspiracy theories blaming big plastic, I'm thinking that the housing used to be metal, which is more durable. This is a plastic piece that gets hit with the high heat from the engine and goes through many heat cycles and I won't like to reuse. Also, it's easier for the tech to install an all-in-one as opposed to have to stock gasket and housing and thermostat.
Old Jan 25, 2025 | 06:41 PM
2001PewterWS6's Avatar
2001PewterWS6
I went with the Katech 174* and don't have any issues either. I also have the thicker 2019 radiator. I tried a billet thermostat housing that came with a thermostat and that failed within 6 months. Went back to the original plastic housing and the Katech thermostat.
