You will lose window indexing and possibly radio presets, seat memory, and display settings depending how long the car is without power. I would personally run through all of the settings menus at some point once you have a known good battery.
Does the display layout change when you turn the rotary **** on the console to select Tour, Sport, or TRack mode? If not, your display is locked in one mode. You need to set display mode to Link to Drive Mode or choose the display mode that you prefer.
- using the right thumb buttons: Scroll left, then up/down to settings. Press OK. You should then be in the center.
- scroll up/down to Display Theme - scroll right
- select Tour, Sport, Track, or Link as desired. Press OK. You should be in the center.
- scroll to the left and up/down to Info or Perf. Press OK. You should be back in the center.
- scroll up/down until you find a sub display you like
- if in Sport personality you can scroll right and choose pocket gauges
For completeness after a battery change: verify battery connections are pushed down, level, then tightened. Verify that the small black wire is still connected to the negative battery clamp - it is very easy to break off.
hi Ron back in the day i used to use a 9volt battery plugged into the cigarette lighter to keep all the pre-sets memory in-tact does that hold true for todays cars
when disconnecting the battery ?
I can't recall anyone saying they have used some kind of voltage backup on C6 or C7. As I noted above, the longer the voltage is low, the more settings may be lost. Note that only the trunk / hatch 12 v receptacle is hot when the ignition is off. It is not a bad idea to go through the settings occasionally...
I used one in my Charger & Infiniti. I would imagine it would work on a Corvette too. Only thing I didn't like about that was it got really hot.
No - it gets hot because you are effectively overcharging the 9volt battery to 13.5 volts until you disconnect the cars battery. Sounds like a bad idea! Overcharged batteries have been known to explode / catch on fire.
Because of issues with the stupid positive buss-plate and every instruction I found saying to disassemble it (NOT necessary, btw), I had my battery out or unconnected for nearly all of several days as I diagnosed and finally corrected the issue. All I had to reset on my '18 base St'ray was the window indexing which the DIC told me, along with how to do so when I finally got full power back up correctly.
