I currently have my blower out being ported and after looking at the intake valves i have decided to clean them with a walnut blaster,
i need to rotate the engine to open and close the valves, it is very close almost impossible to get a 24mm socket and ratchet or breaker bar on
the crank bolt due to the steering rack, my solution is to get a 24mm flexible ratcheting box end wrench which should slide in
