C7 throttle issue
Old Feb 12, 2025 | 10:44 AM
Trex1331's Avatar
Trex1331
Cruising
Default C7 throttle issue
I have 14' stingray z51 7 speed and I'm having an odd behavior with the throttle when I first start out. The car starts to pulse the throttle and starts bucking with even pressure on the pedal.
if I let out it will stop but if I go back in to it almost immediately it will do it again. This doesn't happen everytime
I have a Soler throttle controller installed and wondering if this may be causing the issue. Haven't had a chance to test that theory as I haven't been able to get free time with it again. This issue wasn't there prior to the install so I'm wondering if I may have a bad throttle controller unit. I've reached out to Soler and waiting to hear back from them.
Another theory I have is maybe the wider tires I was able to go with and the traction control is engaging because of it.
I was able to stuff z06 width tires on my stingray front - 285/30/19
rear - 335/25/20.
I'm just trying to get some insight on what may be the cause this if anyone else has had similar issues. before I'm able to start doing some troubleshooting
Popular Reply
Feb 13, 2026, 04:22 PM
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
Hi everyone,
If anyone is experiencing any issues of any kind with one of our products, please feel free to reach out to us directly. We’re happy to help and stand behind what we make.
You can contact us by:
support@solerengineering.com
251-468-9786
PM here on the forum
We typically respond within 24–48 hours.
We appreciate you all and are always here to assist.
Old Feb 12, 2025 | 10:49 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hello there. If you're unable to pinpoint the cause, we may suggest bringing it to a Chevrolet dealership to have a deeper diagnosis performed. Our team can help with that should you need it. Simply send us an email to socialmedia@gm.com to get started.
Old Feb 12, 2025 | 01:34 PM
redman76's Avatar
redman76
St. Jude Donor '09
What gear and RPM does bucking occur? Does it buck every time or just occasionally?
Old Feb 12, 2025 | 01:42 PM
redman76's Avatar
redman76
St. Jude Donor '09
Oh, just reread your post and see it doesn't happen every time. I get bucking occasionally on my '17 GS M7 with Soler TC and TB. It only does it in first gear and I'm holding RPM around 3K before shifting (merging into traffic). I always have Rev Match enabled. I assumed it was due to the performance gear ratios.
We are not the only ones with this issue:
https://www.corvetteforum.com/forums...post1607816548
Old Feb 12, 2025 | 02:06 PM
Trex1331's Avatar
Trex1331
Cruising
Yeah I've only experienced it in first gear when starting off. When it starts if I don't let out of it; it will continue regardless if I press down on the accelerator pedal . It's kind of annoying especially if I'm trying to pull hard from a slow roll or stop. The last time it happened I even turned the sensitivity up and down and still gave the same issue.
I'm really wondering if the TC unit is bad or glitchy
Old Feb 12, 2025 | 02:17 PM
Exia's Avatar
Exia
Did you install the tires at the same time as the controller?
You can see if its the controller by simply unplugging it and testing if the problem goes away. If it does, plug it back in and see if it returns. That will tell you right away, its a simple process to disconnect it.
Old Feb 12, 2025 | 02:43 PM
Trex1331's Avatar
Trex1331
Cruising
Nope I had the throttle controller before the new tires. It did it then so that eliminates the tires after thinking about when I got the controller.
I am going to disconnect it next time I'm at the car. I just didn't have time to troubleshoot it the last time it happened.
I just wanted to ask around see if anyone else has had the same issue and what they may have done to resolve the issue
Also to note it was doing this before a tune.
So it was doing this with the stock tune file.
Old Feb 12, 2025 | 02:59 PM
westsdad's Avatar
westsdad
Easy to disconnect at the accelerator pedal and remove, but be sure to allow the system to power down first or you'll throw a DTC code or end up in limp mode.
Old Feb 12, 2025 | 03:07 PM
westsdad's Avatar
westsdad
Is it worse with the tune?
The throttle response can be tweaked in the tune, so if it was tweaked in the tune, the Soler will be an additional change on top of that and that may be an undesired result versus changing the known stock throttle response.
Old Feb 12, 2025 | 03:08 PM
Trex1331's Avatar
Trex1331
Cruising
Appreciate it, this is what I was going to do first. Finally getting a day off to look at it.
Old Feb 12, 2025 | 03:10 PM
Trex1331's Avatar
Trex1331
Cruising
The throttle response can be tweaked in the tune, so if it was tweaked in the tune the Soler will be an additional change on top of that and that may be an undesired result versus changing the known stock throttle response.
it was the exact same in the stock tune
Old Feb 12, 2025 | 05:46 PM
Exia's Avatar
Exia
Yes, this is mentioned in Soler's instructions for connecting the controller so I didn't mention it because I assume OP read the instructions when installing it.
Old Feb 14, 2025 | 09:11 AM
To hold be a good first step. Hope you find the source of the problem quickly and the solution is an inexpensive one.
Old Feb 14, 2025 | 03:37 PM
Trex1331's Avatar
Trex1331
Cruising
So I did extensive troubleshooting on the car.
I unhooked the throttle controller completely couldn't replicate it. I even cleaned the throttle body for good measure. Traction control wasn't a problem either, it does it with it on or off.
As soon as I would put any setting above the OEM level it would do it every time. So it seems the controller is doing something weird
I'm going to try to provide some video as to what it's doing.
Old Feb 14, 2025 | 05:16 PM
Cfli's Avatar
Cfli
thanks for the update! following this thread
Old Feb 12, 2026 | 11:17 PM
BluegrassMotorsport's Avatar
BluegrassMotorsport
Bumping this thread to see if anything was resolved or if anyone has experienced something similar. I am troubleshooting the same issue now.
Old Feb 13, 2026 | 06:39 AM
guido7834's Avatar
guido7834
Not the same issue, but several years ago I had an issue with the engine revving very high when engaging the clutch with the pre Bluetooth Soler controller installed. I contacted Mike at Soler and he sent a new unit. and the problem was gone. I'd reach out to Soler and see it they can shed some light. It's a great product but like everything else, there's a chance one could be bad...
To C7 throttle issue
Old Feb 13, 2026 | 09:27 AM
LS1AB's Avatar
LS1AB
I had the same issue with mine. There is also a setting in the app for either “manual or auto” make sure it’s in manual mode. That was not my only issue though. I also think using rev match and all the different driving modes changes the throttle progression, and all this is confusing the built in ECM. It has not done anything for a while now. I think the car does a relearn. I have even used AI mode in the app. You can try a new unit too, can’t completely rule that out either?
Old Feb 13, 2026 | 09:38 AM
BluegrassMotorsport
Yeah I changed the mode from Sport to OEM and the problem instantly vanished which tells me it’s the controller for sure. I’m going to try to “relearn” the system today and see if that helps. I had the car tuned a few months ago when I installed headers and I imagine the tuner changed the throttle progression. It was fine before that so I think the controller is good, just maybe needs to relearn the new tune. We’ll see how it goes.
Old Feb 13, 2026 | 12:02 PM
smitty2919's Avatar
smitty2919
That TB controller is taking your gas pedal signals and altering them and then sending them to the TB. That's what these types of controllers do. Which means you are relying on 3rd party quality electronic devices to control your TB opening and closing.
Get rid of that throttle controller and pick up a Mamo Ported TB. It's a OEM GM TB/electronics and doesn't have 3rd party signal conditioning to go wrong and it does everything your TB controller does. Improves tip in driveability.
