Afm
Old Mar 9, 2025 | 08:14 AM
Z4toc7's Avatar
Z4toc7
5th Gear
Default Afm
Question: with auto trans using sport and track modes can you avoid AFM activation?
Old Mar 9, 2025 | 10:02 AM
PJO's Avatar
PJO
Veteran: Marine Corps
AFM and DOD is active in an automatic in all modes other then manual or paddle shift mode.
Old Mar 9, 2025 | 07:00 PM
Old Mar 9, 2025 | 08:03 PM
JK 23112's Avatar
JK 23112
Yep; if you have a C7 with the A8, that AFM will kick in all the time unless you drive in manual mode. If you have the M7, then the car will only go into V4 operation when you drive in "ECO" mode.
I had a C7 with a manual, so it was not an issue. My wife had a C7 with the automatic, so we bought a Range AFM device. It plugs into the OBD-II port underneath the steering wheel. It prevents the engine from going into V4 mode no matter what. I highly recommend this if you have a C7 with the A8, particularly if you intend to keep the car for a long time.
Old Mar 9, 2025 | 08:43 PM
socal_tom's Avatar
socal_tom
What kind of difference do you notice with the AFM device, I have a 2015 auto
Old Mar 9, 2025 | 08:52 PM
JK 23112's Avatar
JK 23112
Originally Posted by socal_tom
What kind of difference do you notice with the AFM, I have a 2915 auto
It drove just fine. No more of that annoying 'thud' when it went in and out of V4 mode.
The highway fuel economy of a C7 is excellent - no need to try to squeeze out 1 more mile per gallon by running four of your cylinders dry.
Old Mar 10, 2025 | 07:22 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I had a tuner turn mine off. Not an issue since.
Old Mar 10, 2025 | 08:02 AM
Tinkertech's Avatar
Tinkertech
I tuned mine out myself with a Diablo I3.
Old Mar 10, 2025 | 09:03 AM
Squeaky Wheel's Avatar
Squeaky Wheel
I have one plugged in full time and don’t even know it’s there. Engine stays in V8 full time. Wouldn’t own an automatic without it.
Old Mar 10, 2025 | 09:39 AM
bearone2's Avatar
bearone2
what about for emissions??
Old Mar 10, 2025 | 10:20 AM
Squeaky Wheel
No testing in KY, but it’s my understanding that if you remove it and drive about 100 miles it leaves no evidence it was ever installed and the car should pass inspection just fine.
Old Mar 10, 2025 | 12:23 PM
bassmobile's Avatar
bassmobile
Range AMF Disabler, stays plugged in 24/7. I didn't buy a Corvette to drive it in V4 mode!
Old Mar 10, 2025 | 04:20 PM
bearone2's Avatar
bearone2
there's a post here, horror show about following range personnel recommendations, failing emissions, not sure if ever resolved!!
Old Mar 10, 2025 | 08:22 PM
aklim's Avatar
aklim
Me too. Also increased the throttle tip in for better throttle response and Diablew also altered the shifting a bit.
Old Mar 10, 2025 | 08:23 PM
aklim's Avatar
aklim
I would think that if you pull it out a month or so and daily drive it, life should be good.
Old Mar 11, 2025 | 06:36 AM
Tinkertech's Avatar
Tinkertech
No need to 'pull out' the Diablo I3.
Once tuned, it stays and does not effect emissions testing and GM can't tell. But I'd tune it back to stock before any engine work at a dealership.
Old Mar 11, 2025 | 07:38 AM
aklim's Avatar
aklim
I kicked it out a couple of times. Didn't want to be "3rd time lucky" and have to replace the OBD port. Figured it was a sign.
To Afm
Old Mar 11, 2025 | 08:16 AM
TxLefty's Avatar
TxLefty
I pull mine out and run some errands for a couple of days. No issues. Would tune it out but still have that pesky warranty.
Old Mar 11, 2025 | 09:20 AM
aklim's Avatar
aklim
Diablo, from what Dcasole said doesn't void the warranty since it doesn't alter the CSV file.
Old Mar 11, 2025 | 02:32 PM
TxLefty's Avatar
TxLefty
I would like to believe them, as that is cleaner, but they only have to wrong once for me to lose the warranty.
