Battery?
Old Jul 21, 2025 | 11:41 AM
06blackvert's Avatar
06blackvert
Default Battery?
So I bought a 2018 Grand Sport last month with 22k miles on it. I changed all the fluids and everything was clean and looked good. I don't drive the car very often (I have only put about 150 miles on it since I bought it. This morning I took the car out and the turn signals had no chime and the seat belt chime seemed muffled. After driving it for about 30 minutes everything went back to normal. I am pretty sure the battery is the original. Do you guys think the battery may be going south?
Old Jul 21, 2025 | 11:44 AM
Macleod52's Avatar
Macleod52
If it's the original battery, then yes.
Old Jul 21, 2025 | 11:49 AM
RacerRik's Avatar
RacerRik
Yes the battery is very likely at its end of life. Recommend replacement with AC Delco Gold AGM battery. Fits like original and is reasonable cost. You can buy on Amazon for about $175. Yes Amazon can ship AGM batteries since they will not leak if tipped over during shipping.
I replaced my 2018 battery a year ago. The new AGM battery has been working fine.
Old Jul 21, 2025 | 12:40 PM
calvins's Avatar
calvins
Oldtimer
Yes, by all means replace it! These cars are REALLY finicky about the battery. I only use OEM but people have gone gels with success
Old Jul 21, 2025 | 01:57 PM
GOLD72's Avatar
GOLD72
The electronics are very sensitive to battery voltage state. You will likely get electrical glitches not allowing the start sequence to be enabled well before there is a battery loss of ability to spin the engine for starting. Yes it is time if original factory battery.
Old Jul 21, 2025 | 02:26 PM
TxLefty's Avatar
TxLefty
If you're going to do it yourself, I'd suggest finding one with a handle.
Old Jul 21, 2025 | 03:12 PM
BELVIN20's Avatar
BELVIN20
Pick a nice cool morning to tackle the job, since original battery has no handle, it will make you sweat getting it out. A lot of posts giving you procedure on connections, take a look if unfamiliar with the C7 electrical, likely they will save you a lot of grief with the connections.
Old Jul 21, 2025 | 06:28 PM
Photomania's Avatar
Photomania
I have replaced two C7 batteries. Neither had a handle. I used a leather belt to hoist one out. Just slipped it under the bottom of the battery. I used a heavy duty bungee cord for the other one. I bought a NAPA brand replacement and it was guaranteed to fit but it was actually a half inch shorter than the OEM battery. So i had to add a block of wood under the retainer to hold it securely. The second replacement was a AAA and it has been fine. But I think the AC Delco from Amazon is the best deal.
Old Jul 21, 2025 | 07:16 PM
bearone2's Avatar
bearone2
definitely going south!!
Old Jul 21, 2025 | 07:34 PM
RacerRik's Avatar
RacerRik
ACDelco Gold 48AGM is the one I ordered from Amazon and it has handles and it was the exact same size as the OEM battery. Some people will say the car's charging system is not designed for AGM batteries. This may be true, but many folks including myself have seen no issues with using an AGM battery.
Old Jul 21, 2025 | 07:56 PM
06blackvert
This is all great info and I really appreciate it. I am gonna order a battery tonight.
Old Jul 21, 2025 | 09:00 PM
BigBS's Avatar
BigBS
May want to consider a trickle charger for it, as well if you don't drive it much.
Old Jul 21, 2025 | 09:02 PM
06blackvert
I have one and I never use it. I guess I need to start using it.
Old Jul 21, 2025 | 09:19 PM
aklim's Avatar
aklim
Would a parts house be able to do a battery test? I would think so as long as it isn't a hybrid.
Old Jul 21, 2025 | 09:39 PM
DanaM's Avatar
DanaM
Yes They would be able to do it for free.
Old Jul 21, 2025 | 09:41 PM
DanaM's Avatar
DanaM
exactly what I have. Actually ordered it from Walmart because it was cheaper than Amazon and the shipping was a few days faster. And I never ever want a battery in this car that doesn't have handles. It was hell taking out the old one.
Old Jul 21, 2025 | 09:47 PM
RUBYREDVET's Avatar
RUBYREDVET
I use one most of the time.
To Battery?
Old Jul 21, 2025 | 10:30 PM
aklim's Avatar
aklim
I have parked my car at the airport for 2 weeks at a time and starts just fine. I would use it at 3 weeks or longer of no use.
Old Jul 22, 2025 | 01:30 AM
Have the battery tested and replace if needed.
Old Jul 22, 2025 | 03:20 PM
vanlieremead's Avatar
vanlieremead
If you order from Amazon, what about the old battery? Usually you get a core credit. Just drop it off?
